Originally Posted by bazookaworm Eventually I will, but a FX-62 can't nearly draw as much power than a Q6600 @ 3ghz can it? |
On average, yes. The FX62 probably draws more @ idle and mid-loads. Remember that most apps don't use more than 2 cores, so even though you would have 4...it doesn't mean they're in use. Now... at full-bore 100%/4 cores(and O/Ced-vCore increased)... it'll use more than the FX62.
