Old May 3, 2007, 03:40 PM
Thumbs up PSU recommendation for the Antec 180b case
Hi I'm buying a 180b case which need a PSU with long enough cables. Could you help me decide? Thanks
Old May 3, 2007, 04:02 PM
Babrbarossa's Avatar
Welcome to the Forum! SKYMTL is our PSU expert, but I know that the OCZ GameXStream 700W is on sale for $114 at NCIX right now, which is a great deal, and a good PSU. It has very long cables- I use it in my p180, and I have a 680i board which has the 8pin connector at the very top of the board and it works fine.
Old May 3, 2007, 04:31 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
The longest I have encountered are on the Silverstone ST50EF.
Then again, I haven't opened up the OP650 I just got.
Old May 4, 2007, 12:48 PM
Cptn Vortex's Avatar
Many of the OCZ's and the Seasonic S12's have 22-24" main and 12V ATX connectors, that work great in the P180. Most compatibility problems come from the Motherboard being used, and the location of the 12V ATX plug. When it is way up in the top left corner, it makes it real hard to reach, especially with a videocard in the way. Also hello all you crazy Nuck's!
Old May 4, 2007, 06:17 PM
Hey! Welcome Cap'n!
Old August 3, 2007, 09:14 AM
milkoholicbear's Avatar
I am using an Antec NeoHE 500W in a P180, and the cables are long enough.
Old August 5, 2007, 08:42 AM
Mibs's Avatar
I'm using the P180 as well. It's tough to get the cables to fit. I have the PC P&C Silencer 750 and the only cable that isn't long enough is the 8pin. I need to pick up an extension for it because right now It stretches across the board and over my video card...quite shameful I know! This is one tough case for cable management.
Intel C2D E6750 @ 3.52 GHz // EVGA 680i SLI Rev. A1 (P31) // 4 GB OCZ Platinum 800 MHz 4-4-4-15 // PC P&C Silencer 750 Quad // Antec P180 // EVGA 8800 GTS 512 // Samsung Syncmaster 226bw 22" LCD
WC Loop: D-Tek Fuzion V2 // Danger Den Maze 5 // Swiftech MCP655 // Swiftech MicroRes // Thermochill PA 120.2 + 4 x Noctua NF-P12
Old August 5, 2007, 09:27 AM
p182 > p180 for wiring, but no matter the psu I suggest possibly picking up a 4 pin atx extension just in case.
Old August 15, 2007, 07:49 AM
Default Another one that fits the P182
Corsair HX520
Old August 15, 2007, 09:06 AM
Supertim0r's Avatar
an other vote for Corsair HX psu
OCZ are great (powerstream)
the GXS700w is noisy
I also have the Silverstone Zeus 750w with REALLY long wires (but it's noisy)
HTPC case: Silverstone LC17, or Antec NSK2400/Fusion nikitos HTPC Systems & Software 5 April 16, 2008 09:20 PM
Antec P182SE Mirrored Stainless Steel Case Supergrover Cases 10 May 21, 2007 08:47 PM
TheTechLounge reviews Antec Nine Hundred gaming case Babrbarossa Reviews & Articles from the Web 4 March 2, 2007 04:08 AM
