Old October 7, 2008, 03:12 PM
Mr. Gruntsworthy's Avatar
Default 350W in HTPC (comes with Antec Minuet)
After finishing my new gaming PC, I was thinking of chopping up my current computer into a home theatre computer.
This is a basic idea of what the HTPC will look like:
Case: Antec Minuet 350 mATX Black Case (350W)
OS: Windows XP SP3
Processor: Intel Core 2 Duo E4600 @ 2.4GHz, 800MHz FSB
HSF: Stock Intel cooler, some higher grade thermal paste
Motherboard: Intel DG33TL LGA775 Core2Duo MATX MB
Power Supply: Undecided; must be Micro-ATX
Graphics Card: Sapphire HD3650 DDR2 512mb PCI-E
Memory: 3GB total DDR2 @ 667MHz
Hard Drives: 1 x 160GB SATA Seagate Barracuda 7200.11 (OS, apps, local temp storage)
Optical Drives: Asus BC-1205PT Blue-Ray/DVD-RW Combo
TV TUNER:Hauppauge WinTV-HVR 1600 MCE Kit
My question is: Will the 350W PSU that comes with the Antec Minuet be satisfactory for powering this computer? I could downgrade the card a little bit more, but it has to be PCI-E x16 compliant with HDCP enabled.
The store I buy from doesn't offer much in the way of micro ATX PSUs, otherwise i'd just get a 450 to be safe.
or does the Antec Minuet offer usage of standard ATX PSU's?
help much appreciated!
Case: CoolerMaster HAF 932
CPU : Intel i7-5820K 6-core @ 3.3GHz
RAM : 32GB DDR4 2400MHz (G.SKILL Ripjaws)
HDD : Main: 240GB SSD SATA2 (Intel) Storage: 3TB SATA2 (WD Green) Backup: 500GB External USB (Hitatchi)
GFX : Gigabyte GTX 970 4GB
PSU : 750W Corsair Modular PSU
MoBo: Asus X99-A
View : Acer H213H 21.5" @ 1920 x 1080 + random 4:3 monitor
Level/Game Designer, Programmer
I run Durham 3D Printing, an online 3D Print shop!
