Is it possible to just find a better fan and stick that in?
__________________ Phenom x4 9950 BE, Gigabyte MA790GP-DS4H, 2x2GB G.SKILL F2-8000CL5D-4GBPQ 250GB 7200.10/640GB&500GB 7200.11 'Cuda, Samsung SH-S203N/Pioneer DVR-112D Radeon HD 3850 256MB, 22" Acer X223W Corsair TX750W, Generic(?) ATX fulltower case (6x 5.25"/9x 3.5") Sansui G-4700 receiver +2x 60w spks/Yamaha YST-M7 |
I upgraded to the PCP&C 750W Silencer from the GameXstream 700W when mine died, and it was a ton quieter. Despite everyone thinking that an 80mm fan will be louder, it allows for larger heatsinks and is actually quieter. My PC is pretty quiet, 6 Yate Loons in push/pull on my RAD running at ~1000RPM and I cant hear the PSU fan at all unless I put my ear next to it, even under heavy load (Crysis Warhead). Of course you could always do what MacJunky said and just take appart the PSU are replace the fan with a different one. IIRC the one in there now is rated to ~70CFM and 35-40dbA at full speed, so you should try to get a fan that is similar air movement. I'd recommend the Zalman ZM-F3 as it is the best airflow/noise at any volume, and does just over 70CFM at max speed so it would be adequate to cool the PSU at full speed. Here is a link for it at NCIX: NCIX.com - Buy Zalman ZM-F3 120MM Sleeve Bearing Case Fan Black 900/1800RPM 20/34DBA 3PIN Connector - ZM-F3 In Canada. (You can pricematch it to <$6 if you use shopbot/pricecanada)
__________________ QX9650 @ ... | Asus P5Q-E |2x2GB Dominator @ ... VisionTek 4870 @ 825MHz/4.6Ghz|WD 640GB Black PCP&C 750W Silencer | HT Omega Claro X3350 @ 4187MHz |
ok i think i'll try the new fan. I don't really want to buy a new psu as the one i have is good, just noisier. I was maybe thinking of trading it with someone.. but i don't know...
__________________ Mountain Mods u2 UFO Intel qx9650 @ 4.2 ghz 4x1 gb corsair dominator 1066mhz Asus p5e Evga 9800GX2 Xp pro on 2 seagate 320 gb, raid 0 Vista Ultimate on 2 seagate 250 gb, raid 0 Corsair 1000HX WC loop: mcp665, pa 120.2, dtek fuzion, DD 8800 gts full coverage, swiftech mcres-micro |
Just be careful if you replace the fan. Make sure the PSU sits for I'd say like 48h before you even open it to ensure the voltage has discharged. Once opened you should still try your best to avoid touching any capacitors directly otherwise you could get shocked rather badly. Definitely look up some safety stuff cause I don't really know the exact time period you should wait.
__________________ Xeon Quad X3350 | 3.40GHz (Damn X38 chipset) ASUS Maximus Formula | BIOS RF0410 2GB Corsair Dominator | 850MHz 4-4-4-12-2T 2GB OCZ Platinum Rev2 | 850MHz 4-4-4-12-2T HIS ICEQ4 Turbo HD4850 @ 700/1200 X-Fi XtremeMusic Antec TruePower Quattro 850W Antec 900 [ HEATWARE ] |
I replaced the fan in my OCZ Gamextreme with a noctua nf-p12 and it made a world of difference. The psu spinns that fan pretty slow so it is all but inaudible. To discharge the caps just turn off the switch on the psu while the system is running that will take care of most of the charge. As for the remainder, it should be gone by the time you can get the case off (CSA has rules regarding such things) however you should always treat it as though they are fully charged just incase. In the event you do get a poke it can't hurt you (seriously), maybe a black mark on your finger and enough to make you jump up and down and swear a lot but that's it.
__________________ Q6600 @ 3.6GHz w/ D-Tek Fusion Gigabyte GA-P35-DS3R rev.1 2x 2GB PC8000 Mushkin Redlines @ 1000MHz w/5-5-5-12 timings Asus EN8800GT Top stock speed w/ DD Maze5 OCZ Gamer Xtreme 600W PSU Cooler Master Cosmos on water |
A silent PSU is one that has no fans. Well, theoretically, a silent PSU is one that doesn't work, since they do variable emit some electrical noise when running. As you can tell, I'm not a big fan of the overuse of the word "silent". But, if you're looking for a fanless power supply: Silverstone Nightjar 450W Silverstone Nightjar 300W There's also the Antec Phantom 500 and 350, FSP Zen, and a few others (see this Google products search) but I haven't seen them for sale in Canada.
__________________ Workstation: D5400XS Skulltrail : 2x Xeon E5420 Quads @ 2.71GHz + 8GB FB-DIMM DDR2-800 (now on water!) Rocketfish LL case painted black // OCZ EliteXStream 800W 2x VisionTek HD 4850 in CrossFire (I want 8800 Ultras in SLI) --> Sony GDM-FW900 + LVM-37w3se // HT Omega Striker ~ (optical) Pioneer SE-DIR800C ~+ SE-DHP800 / HD 280 Pro HTPC: E1200@2.8 + 610i + 2GB DDR2-800 + 8600GT + Silverstone Kublai KL02 Router (WIP): Intel Atom 230 + Intel PRO/1000 GT + GS108T gigE switch + WRT54GL + a drawer |
| Thread Tools | |
| Display Modes | |
