Old October 6, 2008, 11:21 PM
Level up: 4% Level up: 4% Level up: 4%
Level: 9 - 226 points to level up
Default OCZ GameXStream 700W vs Mushkin 650W
which is better PSU? which one is louder? if you had to choose between the two, which one would you choose?
Old October 6, 2008, 11:37 PM
burebista's Avatar
Level up: 92% Level up: 92% Level up: 92%
Level: 9 - 20 points to level up
Hmm, Fortron vs. Topower, or high ripple in full-load vs. hit-and-miss. Frankly I'd go for Antec EA650 if your budget doesn't allow an Corsair TX650 or HX620.
Old October 7, 2008, 12:04 AM
MpG's Avatar
MpG MpG is online now
Level up: 61% Level up: 61% Level up: 61%
Level: 15 - 253 points to level up
^^^ Seconded ^^^
I'm guessing that you're aiming to buy local, and those are the two most suited offerings? What kind of system are you powering? The GameXStreams are pretty consistent for bad voltage ripple at higher loads. If your system is never going to get anywhere near the PSU max, EVER, it might do the trick just fine. Otherwise, I'd probably give the Mushkin unit a shot.
Assuming, of course, that you're strictly limited to these two choices.
QX9650 @ 4.038GHz (425x9.5) | Asus Formula Maximus | GTX280 (777/1620/1404) | Mushkin XP2-8000 Redline 2x2GB
Q6600 @ 3.6GHz (400x9) | MSI P35 Platinum | 8800GTS 640MB (700/900) | Mushkin EM2-6400 2x2GB
Old October 7, 2008, 07:51 PM
i currently have both psus just wondering which one was better
Old October 7, 2008, 08:48 PM
Level up: 13% Level up: 13% Level up: 13%
Level: 17 - 695 points to level up
Well since you have both, the OCZ GameXStream would be the better choice IMO.
Xeon Quad X3350 | 3.40GHz (Damn X38 chipset)
ASUS Maximus Formula | BIOS RF0410
2GB Corsair Dominator | 850MHz
4-4-4-12-2T
2GB OCZ Platinum Rev2 | 850MHz 4-4-4-12-2T
HIS ICEQ4 Turbo HD4850 @ 700/1200
X-Fi XtremeMusic
Antec TruePower Quattro 850W
Antec 900
[ HEATWARE ]
