<~----> I had it coming... 450w antec is dead. - Hardware Canucks
Old September 25, 2008, 10:15 PM
Skyllz's Avatar
Default I had it coming... 450w antec is dead.
The 450w that came in my SonataII case bit the dust today. After a shutdown it did'nt want to power up again. Tried with another PSU and all the component seems fine...
So between those choices, what PSU would you pick? Those are all avail locally at this shop or another. All for 100-110$.
PC Cyber Canada - For All Your Computer Needs
Is smoke supposed to come out of there?
Old September 25, 2008, 10:22 PM
Skyllz's Avatar
Silly me... the OCZ has a 30$ mail in rebate that I had not seen until I went to NCIX.
OCZ it'll be then. They better have one in stock tomorrow morning.
Old September 25, 2008, 10:23 PM
burebista's Avatar
Corsair TX650.
Old September 25, 2008, 11:05 PM
PC&C:
Don't be to desperate to save a few bucks and then have to buy another in 1 year.
Q6600@3.15Ghz|CNPS9500|GA-EP45T Extreme|GSkill 2GB 1333MHz|Sapphire 4850|OZC GameXtreme 700|XP64
Old September 25, 2008, 11:20 PM
MpG's Avatar
MpG MpG is offline
OCZ's GameXtreme line is definitely a step down from the top tier makes. Tests on them seem to show an above-average (in some cases, right out of spec) amount of voltage ripple, and their power ratings are at only 20 degrees, rather than 40-50 degrees.
I would seriously consider one of the other options, even if it costs a few bucks more. Even a Corsair VX550 would have no trouble with your system, has a much better track record, and is even a few bucks cheaper than the 650.
Old September 26, 2008, 02:27 AM
Personally I have the OCZ GX700W and I am reading that the 4 12v rails are not really that good with modern Video Cards compared to 1 solid 12v rail. I lost my OC from 3.19>>>>3.01 and the only change in the system was a 4850. I would consider something with a single 12v rail, hopefully someone with more experience can explain this a lot better.
Old September 26, 2008, 04:03 AM
1Tanker's Avatar
Yeah...VX550/650 should do nicely. I have the VX550 as well..great PSU.
Old September 26, 2008, 06:26 AM
Skyllz's Avatar
thanks for the advices, i'm glad I posted here and that i'm checking this morning.
they have the corsair 750w for 113 - 20mir, sounds like a good choice?
Old September 26, 2008, 10:27 AM
1Tanker's Avatar
Yeah.. the Corsairs have one big 12v rail too... very nice. That 750 would be a good deal for you. GL
Old September 26, 2008, 10:33 AM
paphman910's Avatar
I would stick with the cosair power supply. The 120mm fan is going to be very silent.
Paphman910
