Old September 15, 2008, 07:41 PM
derrXIII's Avatar
Default PSU Help Plz
Alright. i have a psu 650w psu [logisys 650w] and it has 1 8pin connecter,
i use that for my CPU power since it requires and 8-pin instead of a 4-pin.
now when i put in my 2 4850's, my psu fluxes out during stress and shuts down.
it runs well with 1 4850. no im wondering are my 8-pins and 6-pins on the same rail or something? cuz im really confused, 650 should be enough. now what if im going to use a 2molex to 8-pin for my CPU power instead. would that fix my problem since my cpu and gpu's wont be on the same rails [if they even are, or if they ARE supposed to be like that :\]. srry dudz ima noob
Q6600 @ 3.6GHz (400x9) | Biostar i45 | 4850 (700/2010) | G.Skill F2 PC2-8000 @ 800Mhz 2x2GB
Old September 15, 2008, 07:43 PM
try and get to the Antec site and use the PSU calculator!
Acer 5920G ( Stock Air ) no OC:P
At least its DX10!
Old September 16, 2008, 12:24 AM
burebista's Avatar
Logisys is not a PSU is just a bunch of cheap electronic components and wires closed in a metal box and sold as a PSU.
Have mercy for your Quad and two HD4850 and change that craptacular PSU with a good one. Corsair VX550/TX650 for example.
Old September 16, 2008, 05:43 AM
JD JD is offline
I agree with you. I'm surprised that Logisys PSU hasn't blown up and killed all your hardware yet...
Old September 16, 2008, 07:08 AM
Dashock's Avatar
Hello derrXIII, yes like many other members have suggested please buy a powersupply with atleast 650-700 watts so youll have from a manufacture's such as Corsair,Antec or even OCZ. One 4850 card at load with the whole system plugged in takes 244 watts and that is stock clock i believe. Have a look at Skymtl's latest GTX 260 review on the last page of power consumption will give you an idea.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old September 16, 2008, 08:27 AM
Definitely get a new PSU before you end up having to make a forum post here about how your comp blew up and you need a new one! lol. That PSU is not structured right in order to provide you power for two 4850's.
