Old September 14, 2008, 07:43 PM
Infiniti's Avatar
Default Enough Power?
Hey all, is this PSU: NCIX.com - Buy OCZ StealthXStream OCZ500SXS 500W ATX12V 24PIN Active PFC ATX Power Supply 120MM Fan Black - OCZ500SXS In Canada. enough to power an E8400, 8800GTX, two HDs, one burner, all connected to a P5Q-Pro?
Old September 14, 2008, 07:55 PM
its tight dude....
Old September 14, 2008, 08:07 PM
you'll be fine.
but i don't like ocz so i'd recommend something else.
Old September 14, 2008, 08:32 PM
Iamcanadian7's Avatar
I'm assuming your going with this one because it's cheap, in which case it should be fine.
Although personally I would go with a corsair or PCP&C but they are in the $100 range.
Old September 14, 2008, 10:19 PM
Infiniti's Avatar
Okay, well this was for a friend, but I'm going to just give him my PSU and then buy a Quattro 850W for myself.. Then I'll have more upgrade options for a Nehalem system.
Old September 14, 2008, 11:25 PM
My 8800 GTS was fine off a 500W Antec Earthwatts PSU ... It would drop down into the 11.6V range under load, though, which wasn't too encouraging.
With the 8800 GTX and a power supply that's probably in the same league as that Antec, I would say it will probably be fine, but expect fairly significant voltage drops under load. I would probably spend the extra $20-$30 and get a 600W or better PSU.
Old September 15, 2008, 01:25 AM
Infiniti's Avatar
After some consideration, I think I'm getting this for my friend: Anitec.ca - Cooler Master eXtreme Power 600W Power Supply It comes with two PCI-e power connectors already, so there is enough power for the 8800GTX.
