  #21 (permalink)
Old September 7, 2008, 06:56 PM
3.0charlie's Avatar
Originally Posted by Dwayne View Post
Do you think folding both CPU and GPU client running will put some stress on the system for a good test? I have them both running and the CPU usage is 85% - 100% on both cores.
I plan on letting it run all night, but I would run Prime95 to prove the system instead. Just not sure if folding will be enough stress.
Thanks in advance!
Folding creates stresses that other softwares don't reproduce. It's simply a program amongst others that I use for stability.
Hydro-Quebec is salivating...
  #22 (permalink)
Old September 7, 2008, 07:02 PM
geokilla's Avatar
Here's something weird. My system was over 2 hours OCCT stable last night, turned it off, forgot if I saved the BIOS settings or not so I lowered the vcore by one notch, 1 hour stable, so it's not enough. Go into BIOS, raise the vcore a notch. Still not stable. Raise the vcore again, OCCT failed within 10 minutes. How the hell did that happen?
Is OCCT that reliable....? >.<
  #23 (permalink)
Old September 7, 2008, 07:05 PM
Dwayne's Avatar
That's good to know. I ran OCCT for 2 hours while I browsed and it ran clean. That was after I ran an hour of Prime95. I ran an hour or so of WoW and it was stable too. It is not a real aggressive OC from what I have seen from others, but it is good enough for me for now.
Dwayne's Rig - Asus Prime Z370-A : i7 8700k : Corsair Vengeance 32 GB DDR4-3000 : Corsair RM650x PSU : Corsair H100i V2: Fractal Design Meshify C : EVGA GTX 1080 : Arctic Accelero Xtreme III Cooler
HTPC - GigaByte H67MA-UD2H : i3 2100 : 8 GB Mushkin Silverline Stiletto : Antec TruPower 550W : : Corsair H100 : EVGA GTX 1050 SC : Corsair 650D: Kingston 60 GB SSD Boot
Tablet - Asus Surface clone
Wife's Rig - MSI GL72M 7RDX
