Old September 7, 2008, 11:48 AM
Dwayne's Avatar
I agree there is not quick full test, but if I can get through 30 min before I get to 400 FSB then I figure I am pretty good. My other settings are keeping the PCIe at 100 and I am trying to keep my memory close to its 1066 rated speed. Once I hit 400 FSB I will run a battery of stress and benches and if they all pass I will be a happy camper.
enaberif - after I downloaded and ran Orthos I notices the same settings and figured it was the same. Like you say, it is a very nice interface though :)
I plan on running the Furmark to stress the video card at my new speed, I think that was a good one. OCCT for 2 hours as was suggested and then if they are both stable I will turn on my folding again and watch what happens. But I will try and find things to stress my system at its new speed.
Dwayne's Rig - Asus Prime Z370-A : i7 8700k : Corsair Vengeance 32 GB DDR4-3000 : Corsair RM650x PSU : Corsair H100i V2: Fractal Design Meshify C : EVGA GTX 1080 :
HTPC - GigaByte H67MA-UD2H : i3 2100 : 8 GB Mushkin Silverline Stiletto : Antec TruPower 550W : : Corsair H100 : Sapphire HD 6670 : Corsair 650D: Kingston 60 GB SSD Boot
Tablet - Samsung Tab A 10.1"
Wife's Rig - MSI GL72M 7RDX
Old September 7, 2008, 12:28 PM
sswilson's Avatar
The only issue with Orthos is that it will only do 2 cores (the version I've got anywise...) while the latest versions of Prime95 will do 4 automatically.
Old September 7, 2008, 01:47 PM
geokilla's Avatar
I use OCCT and Linpack now. OCCT for about 2 hours, then I run 50 Linpack tests. If I can get over 10 passes with Linpack, then I consider myself stable.
@3.0. Why don't you like Linpack? It stresses the system way harder than OCCT. Using OCCT, my temps reached around 53C while Linpack took it to 63C. You may think it's a waste of time, but we all have a different opinion on it I guess.
Old September 7, 2008, 01:56 PM
Linpack is new, untested, unknown and who knows what else.
Old September 7, 2008, 03:46 PM
Dadi_oh's Avatar
Oh. Good point. I don't have a quad (yet) so I hadn't thought of that. I picked up a quad on a forum and waiting for it to arrive so I guess I will be using Prime95 if Orthos can't do 4 cores.
Rig1: Q9550 @3.8GHz Vendetta 2, P5Q-PRO, 6GB OCZ Reaper PC2-8500. 5870 1GB, GT240 Physx, Ultra LSP 750W, 2TB internal + 2TB external, 3X23" 5760X1080 eyefinity + GT240 Physx, HAF22 case 3X200mm : Win7 Pro
Rig2: E8200 @3.6GHz Vendetta HSF, DFI P45 LP-JR, 4GB 900MHz, 4870 512MB, X203W 20", Ultra Gladiator Case
Rig3: Q6600@ 3.5GHz H50, P5Q-PRO, 8GB, 8800GTS512, OCZ GameXStream 850W, Samsung 245BW 24" + 19" dual: Snow Leopard + Parallels Win7
Rig4: MAC mini Snow Leopard
Laptop: Macbook Pro 15"
Old September 7, 2008, 06:17 PM
Dwayne's Avatar
Do you think folding both CPU and GPU client running will put some stress on the system for a good test? I have them both running and the CPU usage is 85% - 100% on both cores.
I plan on letting it run all night, but I would run Prime95 to prove the system instead. Just not sure if folding will be enough stress.
Thanks in advance!
Old September 7, 2008, 06:22 PM
Thanks in advance!
Folding is different than how p95 works.
So yes you could have a orthos/p95 system stable but when you try to fold it does different calculations and computations and could find a flaw that nothing else could.
Old September 7, 2008, 06:47 PM
sswilson's Avatar
Orthos has a selection to "Stress CPU with Gromics core" which AFAIK is the same as folding.
  #19 (permalink)
Old September 7, 2008, 06:51 PM
My machine was SmallFFT stable and as soon as I went to try folding it would fail.
Can't say why.. but it did.
  #20 (permalink)
3.0charlie's Avatar
Originally Posted by cadaveca View Post
I'm curious as to why you feel this way about this software...
1. Why would I need another stress testing software when all my rigs are stable with Prime, OCCT and folding?
2. No automatic error reporting.
3. Do you really need such a software, putting so much load on the CPU - something that no other software (even games) cane reproduce? Is it really worth it?
4. I don't like the fact that the core load varies that much. I'm a mechanic by trade, and revving your engine is the best way to damage the internals. Stupid analogy maybe, but it's something I can relate to.
5. How can a test be stable with so little ram, and the same setup unstable with 4 Gb?
6. 64-bit OS allows for a more accurate test? What about the users still working with 32-bit OSes?
Hydro-Quebec is salivating...
