Old September 6, 2008, 10:02 PM
Default Memory Speed vs FSB
Something has been really picking at my brain lately and I'm curious if its something that actually doing harm than good.
Currently in my system I have 4gb of PC2-8000 G.Skill memory and I'm wondering lately if this memory is whats holding back and making my system unstable.
Now that I have the e8600 which runs stock at 3.3ghz @ 10x multiplier when I start to overclock this chip if I run say 450 fsb to give me 4.5ghz that theoretically means I'm running a 1600mhz fsb.
The cpu is a 1333 FSB chip so the 1600 is already over that but the question is do I need pc2-8500 memory rated for 1066 to do this or is it simply a matter of going:
450 x 2 = 900mhz
Meaning my ddr2-1000mhz memory SHOULD be fine or am I pushing a fine line with the overclocking and speed of my memory?
Old September 6, 2008, 10:27 PM
SugarJ's Avatar
As long as you're at a 1:1 ratio, that mem should be good. I'm using the same mem (I think), F2-8000CL5D-4GBPQ, and I've ran mine at up to 1100 Mhz at 5-5-5-15 at 2.1V (using 1.2:1 Mem:fsb ratio). The BSOD errors I get now all point at the CPU, and I'll pump some more volts into it once I'm sure my loop won't leak.
Old September 6, 2008, 10:31 PM
Yah thats what I thought.
New CPU tomorrow.
Old September 6, 2008, 10:32 PM
SugarJ's Avatar
Again? Isn't that your 2nd E8600?
Old September 6, 2008, 10:36 PM
Haven't had time to go in yet to switch it. Hoping tomorrow.
