Old September 4, 2008, 02:03 PM
geokilla's Avatar
Default Trying to Reach 3.8Ghz on E7200
I'm trying to overclock the E7200 to 3.8Ghz on a EP35-DS3L, however it's not passing over a minute of OCCT. I'm trying to get it stable at 3.7Ghz at the moment. The temperatures are fine and they won't pass over 63C when I'm running Linpack.
Here are my BIOS settings:
C1E, EIST, TM2: All disabled
FSB: 390Mhz
PCI-E: 100Mhz
C.I.A.2: Disabled
RAM Multiplier: 2.00 (1:1)
RAM Timings: 5-5-5-15
FSB Voltage: +0.1V
MCH Voltage: Standard
CPU Voltage: 1.375V in BIOS. CPU-Z Idle: 1.328V. CPU-Z Load:1.296V.
Any advice on how to get it up to 3.8Ghz and above is greatly appreciated.
Old September 4, 2008, 03:24 PM
werty316's Avatar
Try increasing some of the voltages (FSB and/or vCore).
What is you memory rated at? I'm assuming its DDR2-800.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Old September 4, 2008, 03:52 PM
geokilla's Avatar
How much vcore can I give in the BIOS, and from CPU-Z? I'm already sitting at 1.3875Vcore in BIOS which is 1.344 during idle and 1.312V under load.
My RAM is rated at DDR800, and it's running at DDR782 right now.
Old September 4, 2008, 07:50 PM
Dashock's Avatar
Try 1.4 volts on the cpu i think your cpu should handle that and turn your ram down a bit as well how much volts are you putting on your ram ?
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old September 5, 2008, 03:35 AM
1Tanker's Avatar
Try bumping vFSB to +2
Try upping vMCH to +2
If those don't stablize things, you may need some more vCore...but i doubt it(you should be safe up to 1.50v for benching sessions, and 1.40v-1.45v for 24/7 usage). On my
GA P35-DS3L w/E8400, i had/have to use vFSB +3, vMCH +3..depending on if i'm running 3D Benches...vPCIe +2 or +3.
Set PCIe speed to 101MHz....Please..it helps!
Set vDIMM to +4(2.20v..but the boards undervolt...that'll give you 2.03v-2.12v)
Also keep in mind that 3.7-3.9 is the average area where these chips(E7200) start getting more stubborn...they don't like trying to be clocked like their cousin...the E8400. GL geokilla
Old September 5, 2008, 01:32 PM
geokilla's Avatar
I'm a bit scared at going to 1.4V.....However, I will try it.
The RAM is running at the lowest multiplier I believe, which is 1:1, running BELOW the rated DDR800 at 5-5-5-15 with 1.9Vdimm. I've seen people post on NCIX that they got their RAM to run at DDR900+ with 2.1V.
@1Tanker. If I set the vFSB and vMCH to +0.2, would I damage the system/motherboard/CPU? I don't have active cooling on the MCH or south bridge or anything like that. All I have is a front intake and rear exhaust in my computer, plus the OCZ Vendetta 2 and the PSU fan. Plus, how would setting the vPCI-E to +0.2 or +0.3 help? I thought it'd only affect my graphic card overclocking and not the CPU. I currently have it at normal voltages for the PCI-E. I'll try setting the vdimm to +0.4 and the PCI-E to 101Mhz and see if it helps.
I'm sitting at 1.312V under load right now. I found something weird with Linpack though. I already raised the voltages up a bit notches, and Linpack constantly finishes at the 5556 second mark, saying that it's passed only 1 out of 50 tests. Anyone got an idea what the problem could be?
Edit: This time, the test finished in 5455 seconsd, passing 7 out of 50 tests. I'll now try raising the voltages a bit more and see what happens. However, I probably won't raise the FSB and MCH yet till I find out whether it'll kill my system components or not since I don't have active cooling on the MCH.
Old September 5, 2008, 02:16 PM
3.0charlie's Avatar
Listen to the man and do what Tanker wrote.
Take a spare fan (even a household fan), open up your case and stick it next to the NB / SB blocks.
Why are you using Linpack? Use OCCT. 30 minutes custom test, 2 hours for full stability.
Download - OCCT Website english
Hydro-Quebec is salivating...
Old September 5, 2008, 03:12 PM
geokilla's Avatar
Err, my case is going to be enclosed in the desk, so a household fan wouldn't work well. It'd only be good for like suicide runs. I do have an AMD stock fan, but I have no idea how I can position it anywhere near the NB and SB.
What's so bad with Linpack? I thought you should aim for at least 5 passes of Linpack to make sure that your system is really stable.
I'm planning to get at least 10 passes on Linpack, then around 3 hours of OCCT, and 2 to 3 hours of Memtest. I'm running Memtest so I can try to get tighter timings.
Old September 5, 2008, 04:47 PM
3.0charlie's Avatar
Case enclosed in a desk is the worst location possible for clean air and good temps.
Linpack? In my 10 years of oc'ing (and 20+ in assembly), I've never heard about Linpack. OCCT is recongnized, fast. No need to test for 3 hours...
And why modify the mem timings when you're trying to overclock and stabilize your CPU? You should know that you oc and test for stability one part at a time - never both CPU and ram in the same session.
bah. do whatever you want.
Old September 5, 2008, 05:37 PM
geokilla's Avatar
Noooo. I'll get a pic of where the computer will go later. I think you understood me wrong.
I'm going to tighten the memory timings AFTER I get a stable overclock. Shoulda made that clear when I typed my post.
IntelBurnTest - The new stress-testing program - XtremeSystems Forums That's Linpack.
