Old September 3, 2008, 08:57 PM
Default Mem. OC. High FSB vs Tight timings
What are your opinions? With my memory people have got 1122MHz at 5-5-5-18 and 4-4-3-10 at 844MHz, which would be better? Is one better for certain things and one better for others?
Old September 3, 2008, 09:31 PM
werty316's Avatar
I'd go for the first option.
If you wanna see what kind of difference you'll there is between both setups, give the Sandra or Everest benchmark a run or two.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
