Old August 31, 2008, 10:52 PM
Default OCing q9550 on stock heatsink?
I tried playing around with the FSB settings in the BIOS, and set it @ 400mhz (default is 333mhz). This makes for a clock speed of 400mhz X 8.5 = 3.4ghz. Every other option is set on auto (I did not manually change the voltage). I monitored the temps on idle and on load. On idle, it is similar to the stock 2.83ghz @ around 46C. On load, it stabilizes to around 65C.
My question: is 65C too high for the stock cooler? Should I buy a third party one? My RAM is 800mhz so my FSB can only go max 400mhz, so I presume the highest OC i'll get is @ 3.4ghz.
Case: Coolermaster Cosmos 1000
Mobo: Gigabyte X48-DS4
CPU: Intel Quad q9550
PSU: Corsair 750w
GPU: Diamond HD4870
RAM: 4gb Corsair XMS2 PC2-6400
HDD: 2 x 640gb WD Caviar
Audio: Auzentech Forte 7.1
OD: Pioneer DVR-216
OS: Vista Ultimate SP1
Old August 31, 2008, 10:59 PM
SugarJ's Avatar
Youll find that most people are uncomfortable with load temps over 65-70 degrees (I am), and heat is hard on electronics.
I'd suggest spending some money on an aftermarket cooler, like the OCZ Vendetta 2 or Xigmatek - HDT-S1283. Both can be found for under $40 and are excellent coolers. See reviews on this site.
Old September 3, 2008, 06:21 PM
misterlarry's Avatar
Simply put: don't do it. I use a Thermalright Ultra 120 Extreme and since I bought that there have been several excellent alternatives show up as SugarJ has pointed out.
The Accelero though has done more to lower my overall case and CPU temps than I could have imagined.
Asus Z97-A - Intel i7 4790K @ 4.0 GHz - Corsair H80 CPU Cooler- 4x8 GB G.Skill Ares DDR3 2400 - EVGA GTX960 4GB
1x240 GB Mushkin Chronos Enhanced SSD - 1x500 GB Seagate Hybrid Momentus - 1X2 TB Western Digital Green - Pioneer DVR-212D - Antec P182 - Rosewill Photon 850 - 2X24" Acer G246HYL - Windows 7 Pro 64 SP1
The world is your oyster. Shuck away my friend, shuck away!
