Old August 31, 2008, 08:06 PM
Default Q9550 clocking @ 2.66ghz instead of 2.83ghz
I've been benching my system lately and I found that when I run the prime95 stress test, I only achieve a clock speed of 2.66ghz (see photo). Has anyone encountered this or know why this is happening, since its supposed to be clocked @ 2.83ghz (this is the clock speed detected in the system properties. Before disabling C1E it was @ 2ghz.
Case: Coolermaster Cosmos 1000
Mobo: Gigabyte X48-DS4
CPU: Intel Quad q9550
PSU: Corsair 750w
GPU: Diamond HD4870
RAM: 4gb Corsair XMS2 PC2-6400
HDD: 2 x 640gb WD Caviar
Audio: Auzentech Forte 7.1
OD: Pioneer DVR-216
OS: Vista Ultimate SP1
Old August 31, 2008, 08:54 PM
Problem solved. For some reason the multiplier was set to 8x in the BIOS, and there was an option to fine tune the multiplier by 0.5 that wasn't set. Weird that this was not set by default.
PSU: Corsair 750w
GPU: Diamond HD4870
OD: Pioneer DVR-216
Old September 1, 2008, 12:29 AM
Dashock's Avatar
yea i had that problem to but setting the multi yerself was the issue well its always good to learn the answers yerself eh lol :p Good temps i personally think above 50 is wayy too hot im gonna try whatever i can to keep temps down.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old September 1, 2008, 04:09 PM
MpG's Avatar
MpG MpG is offline
Nothing wrong with 50 degrees at all, it depends entirely on what kind of cooling you're using.
Old September 2, 2008, 06:57 PM
NyteOwl's Avatar
Default Magical 4 GHz
Ok I know it is possible, after reading the setting for lots who have done it but is there some additional magic to coaxing 4 GHz out of a QX9650?
I spent two evenings trying various settings and the closest I could get was 3.8 but that wasn't stable for games despite running Prim95 for a few hours. Which means it couldn't be relied on 24/7. 4.0GHz would not even boot.
Temperature didn't appear to be a problem as core temps never exceeded 53C and NB never exceeded 49C. All air cooled.
I am wondering if the RAM may be the holdback though the RAM settings don't change between 3.0 and 4.0 GHz. Thoroughly confused as I haven't seriously tried to overclock anything since K6-III/Pentium 2 era when it was *much* simpler.
Rig specs are here: NyeOwl's Perch
Any suggestions would be appreciated. I'm currently running at 3.6 GHZ and things are quite stable. Just can't seem to find that magic #4
Obsolescence is just a lack of imagination.
