  #31 (permalink)
Old September 1, 2008, 08:55 AM
WolfBane's Avatar
gonna go with the chip first and see how high i can go with it :)
I USE EMT ONLY
Remember... Four boxes keep us free: the soap box, the ballot box, the jury box, and the cartridge box.
  #32 (permalink)
Old September 1, 2008, 11:29 AM
WolfBane's Avatar
Ok i ran 3dmark06 and got a score of 13324 on 3dmark is this good ?
I USE EMT ONLY
  #33 (permalink)
Old September 1, 2008, 11:46 AM
Don't worry about 3d06 its all based off CPU anyways.
  #34 (permalink)
Old September 1, 2008, 11:58 AM
WolfBane's Avatar
Ok good deal bud:) gonna run the system this way for a bit and maybe after i get my second wc loop in and vid card cooled better then i will go for more ocing:)
I USE EMT ONLY
  #35 (permalink)
Old September 1, 2008, 01:01 PM
Nice going Dave! you did quite well for a first time OCer. Your clocks with the E3110 makes me impatient for me to get my Biostar and overclock the E8400. I'll be in the same category, never got any luck overclocking the E8400.
If your looking for a lil more juice, good luck on it, you got water cooling, and your temps are just fine!!.
  #36 (permalink)
Old September 1, 2008, 02:54 PM
WolfBane's Avatar
Hey thanks Miggs :)
i wish you luck in your ocing endevours(sp) as well bud:)
I am thinking down the road a bit to build a second rig quad core just to see if i can build one my self:0
And yes i think i did well by going watercooled for my first rig keeps the temps well with in range , and this thing is just purring fantastic right now:)
I look forward to seeing what that chip your getting will do as well :)
I USE EMT ONLY
  #37 (permalink)
Old September 1, 2008, 03:13 PM
cdn_Madrach's Avatar
Great job on learning to OC Wolfbane. You've definately got the bug now lol.
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
Silverstone Strider 1kw modular
4870x2
Ocz Vendetta 2
Top deck Tech Station
Samsung dvd
  #38 (permalink)
Old September 1, 2008, 04:15 PM
WolfBane's Avatar
lol thanks Cdn yea you guys have created a oc monster here lol but i still have alot to learn and still reading and asking all i can :)
I USE EMT ONLY
  #39 (permalink)
Old September 1, 2008, 05:12 PM
sswilson's Avatar
Once you get comfortable with your current OC you can set aside a couple of weeks to find the best secondary settings for your memory.... :)
  #40 (permalink)
Old September 1, 2008, 05:18 PM
Supergrover's Avatar
This is the part I love about a new system, the tweaking.
R.I.P.
