  #21 (permalink)
Old September 1, 2008, 02:54 AM
sswilson's Avatar
Something to keep in mind about OCCT is that it has a temp shut-down feature which is enabled by default. If you're running your chip high according to coretemp but it's still within your "acceptable risk" window under realtemp you'll find that OCCT seems to use the same formula as coretemp so it could shut down based on that. (There is a setting to raise that temp).
I doubt however that a shutdown after almost 2 hours of OCCT is a cpu temp issue.
  #22 (permalink)
Old September 1, 2008, 05:43 AM
WolfBane's Avatar
Ok i couldnt find any report on Occt but i ran prime95 all night and not a problem there :)
so now i will download 3dmark06 and run it and see what it says
I USE EMT ONLY
Remember... Four boxes keep us free: the soap box, the ballot box, the jury box, and the cartridge box.
  #23 (permalink)
Old September 1, 2008, 07:59 AM
WolfBane's Avatar
Ok i ran prime 95 for the last 13 hours no problems , ran Occt again for 2 hours on mix (changed the temp rating to 99 c) no problems said all is stable , so i am just waiting to finish downloading 3dmark 06 and run it:)
I USE EMT ONLY
  #24 (permalink)
Old September 1, 2008, 08:13 AM
You'll hit about 13k or so in 3d06
  #25 (permalink)
Old September 1, 2008, 08:35 AM
WolfBane's Avatar
Ok guys here is what i have see screen shot all running stable !! see anything i need to change ?
I USE EMT ONLY
  #26 (permalink)
Old September 1, 2008, 08:37 AM
WolfBane's Avatar
So is trhat a good score?
should i up my cpu clock?
I USE EMT ONLY
  #27 (permalink)
Old September 1, 2008, 08:40 AM
3.0charlie's Avatar
Well, for a first time oc'er, you did quite well. Keep it up - you can always try to raise the FSB and find the limit of your chip and ram - always keep a close eye on those temps...!
Hydro-Quebec is salivating...
  #28 (permalink)
Old September 1, 2008, 08:44 AM
WolfBane's Avatar
so i would increase the voltage to my FSB and My mem ???
then retest for stability ?
Also what temp shouldnt i go over on my FSB or CPU or Mem???
I USE EMT ONLY
  #29 (permalink)
Old September 1, 2008, 08:46 AM
WolfBane's Avatar
Also on my memory should i lower my values from 5-5-5-15 to say 4-4-4-12?
Would that make my system run faster ?
Man i got the need for speed bug now lol
still learning alot and h ave alot to learbn:)
I USE EMT ONLY
  #30 (permalink)
Old September 1, 2008, 08:49 AM
3.0charlie's Avatar
OC either the chip, or the ram one at a time, never both.
Raise the fsb without touching the Vcore - if it fails stability, raise until 1.45V is reached, or 65C under load.
You could try to tighten the ram timings, but CAS4 is asking a lot. You can always try, maybe you'll find a setting that will work for you.
