Old August 28, 2008, 07:19 PM
yycraven's Avatar
Default E8xxx Series Overclocking
So looked around on here and did not see any E8xxx series cpu speed OCed thread, Showing everyone's overclocked E8xxx cpu's
So post your results cpu-z and tell us if your on Air or if your drowning it( underwater).
I'll start I guess, using air cooled with a CoolerMaster Hyper 212 .
ASRock Extreme 3,2500K,NH-D14,Patriot G2 16GB ,WD 750GB,640GB Sata ,2 GTX 470 SLi Thermaltake toughpower XT850W,Tech Station. V243H,2253LW LCD
heatware
Old August 28, 2008, 07:20 PM
do a search on my name.. you'll see my threads on 8400 and 8600 clocks ;)
8400 = 4.4 stable ; 4.2 safe
8600 = 4.7 windows load (crashes on test) ; 4.3 stable
Old August 28, 2008, 07:36 PM
Infiniti's Avatar
Eh... you guys all have great temps, mine is being drowned, but still gets like 40 idle and 80 load at 4Ghz.. (E8400)
Old August 28, 2008, 07:39 PM
You have a problem.. and I'm thinking fans. Aren't you running 120x38mm fans? Seriously change them out for some 120x25 fans.
Old August 28, 2008, 07:41 PM
Infiniti's Avatar
Umm, but aren't 38mm fans better? They apparently generate more static pressure, and for the MCR320, more static pressure = , right? Oh and I changed out the dual rad for a triple.
Old August 28, 2008, 07:43 PM
No 38mm aren't always better and this is what I'm trying to say :P If your cpu block is good, and your pump is good, and your rad is good, and your fluid is good... whats left?
Fans.
Amuse me.. switch them out.
Old August 28, 2008, 08:11 PM
Infiniti's Avatar
Fans.
Eh.. That'll take so long.. Should I drain my loop before I do it?
Old August 28, 2008, 08:12 PM
only if you can't get to the fans.
Old August 28, 2008, 08:14 PM
Infiniti's Avatar
Yay, no more loop draining then. It should be fine if all the fans are different right, because I don't have 3 of the same available..
Old August 28, 2008, 08:15 PM
better to keep them the same.. but for testing not really.
