  #81 (permalink)
Old September 2, 2008, 07:12 AM
Nope.
Post a screenie of your System Information window.
You've got something funny going on in your system.
Gigabyte X58A-UD3R | i7 930 | Corsair H50
G.Skill RipJaws 4x2 GB DDR3 | HIS Radeon HD 5870
3x Intel X25-M 80 GB RAID-0; OCZ Agility 120 GB | Samsung SH-S243D
Corsair HX1000 | Dell 3007WFP & Samsung 204T | 7 Ultimate x64
  #82 (permalink)
Old September 2, 2008, 09:12 AM
Nothing funny is going on.
64bit and 32bit act the EXACT same way with 4gb of memory. Always ends up with less than 4gb for actual usage.
  #83 (permalink)
Old September 2, 2008, 04:49 PM
Again, no.
Post a screenie of your system information tab.
You've either got remapping disabled or something else very strange is going on.
I can utilize my full 4 GB or 8 GB...there's none missing.
The rest of us aren't missing memory on our x64 OSes; it's just you.
  #84 (permalink)
Old September 2, 2008, 05:03 PM
SugarJ's Avatar
Sorry tio interject here, but just noticed this in my S.I. when I checked.
What the hell is going on? Why can't I see 4Gb? This is a fresh install about 2 weeks old of 64-bit Home Premium.
  #85 (permalink)
Originally Posted by -n7- View Post
Again, no.
Post your screenshot of your task manager then.
  #86 (permalink)
Old September 2, 2008, 05:04 PM
Because of the same reason as 32bit
Geez.
  #87 (permalink)
Old September 2, 2008, 05:10 PM
SugarJ's Avatar
Yah, but it was ok with my Giga-byte mobo, I've checked that before. This is new since my X-48 went in.
Geez.....
See how frustrating that is? C'mon. I was in the industry before Windows 3.0. Been building systems since '91. I do know a fair bit about computers and OS's.
  #88 (permalink)
Old September 2, 2008, 05:14 PM
Geez.....
Was like that with my p35 and now is like it with my P45
  #89 (permalink)
Old September 2, 2008, 05:19 PM
SugarJ's Avatar
apparently, looks like it has to do with memory remapping options in BIOS. There weren't any on the GA-P35-DS3L, it did it automatically. I don't remember seeing any in my Asrock BIOS, gotta reboot to look.
If there aren't any available, this mobo might be going up for sale.
Edit: There was a PCI re-mapping option, I did have it enabled on this Asrock, but it doesn't appear to work. I tried disabling it, just in case, no go.
Looks like more of a Bios issue than a Vista issue.
  #90 (permalink)
Old September 2, 2008, 06:20 PM
It's entirely to do with what your motherboard/bios has it set to, or in some cases, if it's an option at all. (I'm sure some crappy boards don't remap, though i personally haven't worked on one that doesn't yet.)
The only time enaberif is correct in saying you "lose" memory on an x64 OS is when remapping is either disabled or it's not supported by the motherboard.
And on any half-decent motherboard, remapping options should be there.
enaberif, here's your screenies.
Oh, & here's with remapping off, just for you, enaberif.
In case you guys don't know what you are looking for; look at "Total Physical Memory".
That's what available for use.
"Installed" is just what's physically installed; not necessarily what's available.
"Available" is what's not being actively used.
