<~----> Mushkin Ascent 8000(100mhz) and E8400 - Page 8 - Hardware Canucks
  #71 (permalink)
Old August 29, 2008, 06:53 AM
mattlef's Avatar
Alright I have it 6 hours stable :D
But I realized i'm a dumbass and have the 32bit version of vista intalled lol, so I'm gonna go blow out the 32 and throw in the 64 bit.... whats the point of having 4gig of ram when you are only using 3 with the 32bit os right?
the work never ends lol
So I'm assuming install everything with the standard clock?
My Rig:
Motivate TJ07
Check out my Build log!!!
Motivation: Sponsored by Galaxy
Upcoming Changes/Upgrades:
Check the build-log for more
  #72 (permalink)
Old August 29, 2008, 07:10 AM
makes no difference.
You won't see any extra benefit.
  #73 (permalink)
Old August 29, 2008, 07:19 AM
mattlef's Avatar
you mean I wont see a difference between installing with standard or oc? or that I wont notice the difference between the 32 and 64 bit os?
My Rig:
Motivate TJ07
  #74 (permalink)
Old August 29, 2008, 07:35 AM
Dashock's Avatar
He means you wont see a big difference in the usage of the whole 4 gb kit of yer ram from the 3.25 gbs that you can only use with the 32 bit operating system.
Intel Xeon E3110 @ 3.0ghz
XFX 8800 GT Alpha Dog Edition
Asus P5Q-E
Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v
OCZ 600W GameXstream
Seagate 7200.11 500gb
Seagate 7200.10 320gb
Antec Spot Cool
Logitech X-230
Samsung 32" 720P HDTV
Coolermaster Cosmos S/
  #75 (permalink)
Old August 29, 2008, 07:47 AM
mattlef's Avatar
Granted, there wont be a massive increase in performance, but having that extra 500megs of physical ram is never a bad thing.... as well it goes down to the whole "I paid for 4, i want to use 4" type of arguement.
My Rig:
Motivate TJ07
  #76 (permalink)
Old August 29, 2008, 08:08 AM
Dashock's Avatar
true im happy with xp even though i like vista its just much easier for me to use xp i use both xp and vista but granted i spend almost 90 percent of my time on xp.
Asus P5Q-E
Antec Spot Cool
Logitech X-230
  #77 (permalink)
Old August 29, 2008, 08:09 AM
You still don't your full 4gb of memory. 64bit still ends up with less like 3.5 or 3.7
And you don't need Vista for 64bit Xp has a perfectly fine solution.
  #78 (permalink)
Old August 29, 2008, 08:30 AM
mattlef's Avatar
I actually haven't encountered any issues with Vista, and for some reason, I've actually gotten used to it, to the point I prefer it over XP...
My Rig:
Motivate TJ07
  #79 (permalink)
Old September 1, 2008, 10:43 PM
Eh?
If you have remapping enabled on your x64 system, you should be getting your full 4 GB.
I have my full 4 GB & full 8 GB available on both systems; one using a P5B Deluxe; the other a P5Q Deluxe.
Gigabyte X58A-UD3R | i7 930 | Corsair H50
G.Skill RipJaws 4x2 GB DDR3 | HIS Radeon HD 5870
3x Intel X25-M 80 GB RAID-0; OCZ Agility 120 GB | Samsung SH-S243D
Corsair HX1000 | Dell 3007WFP & Samsung 204T | 7 Ultimate x64
  #80 (permalink)
Old September 1, 2008, 11:03 PM
Originally Posted by -n7- View Post
Eh?
Nope.
The system will "know" it has 4gb
But your OS will still have less just like a 32bit OS.
