  #51 (permalink)
Old August 28, 2008, 09:10 PM
mattlef's Avatar
Originally Posted by enaberif View Post
Then you aren't running your cpu:mem at 1:1 ... that means your running a FSB of 500 mhz to hit 1000mhz memory.
again more memtest crashes :S
heres what the ram is showing in cpuZ
I as well have upped the Dram Voltage to 2.16 and the NB Voltage to 1.4...
hopefully this will do the trick :S
CC-HotSpot Host
YouTube Instagram Twitter
  #52 (permalink)
Old August 28, 2008, 09:13 PM
What multiplier are you running for this 8400? 8400s are x9
  #53 (permalink)
mattlef's Avatar
I'm running a 500fsb at x8
CC-HotSpot Host
  #54 (permalink)
Old August 28, 2008, 09:14 PM
errr .. I see two probs with that screen.
1) DDR3? Don't you have DDR2 memory?
2) Your 8400 should be running at x9 multiplier.. looks like your running x8
  #55 (permalink)
Old August 28, 2008, 09:15 PM
mattlef's Avatar
That ddr3 has me wondering as well, as it is DDR2 memory.... bad ram maybe?
CC-HotSpot Host
  #56 (permalink)
Old August 28, 2008, 09:17 PM
OOOH!
You have 1.46 upgrade to 1.47 and see if it fixes it.. and also go back into your bios and change your system to use a x9 multi and appropriate FSB to get back to where you are.
There should be no need to drop to x8
  #57 (permalink)
Old August 28, 2008, 09:18 PM
mattlef's Avatar
heres the CPUZ with everything:
CC-HotSpot Host
  #58 (permalink)
Old August 28, 2008, 09:24 PM
1) Ugrade CPU-Z to 1.47
2) Change your multi back to x9 and set your fsb to 440 to get your 4.0
  #59 (permalink)
Old August 28, 2008, 09:29 PM
mattlef's Avatar
I brought the FSB to 450, and multi to x9...
However, my ram is back to DRAM:FSB is 5:6... Strap is 333...
CC-HotSpot Host
  #60 (permalink)
Old August 28, 2008, 09:33 PM
drop your strap to 266 and see if it makes a diff.
