  #41 (permalink)
Old August 28, 2008, 07:59 PM
mattlef's Avatar
Originally Posted by enaberif View Post
Try 1.32 .. you could even try 1.4 if you wanted... just keep an eye on your NB temps.
Northbridge aka motherboard in Everest or are you using a seperate app from everest coretemp or realtemp to watch the nb temps?
CC-HotSpot Host
YouTube Instagram Twitter
  #42 (permalink)
Old August 28, 2008, 08:05 PM
I only use HWMonitor to watch my temps for anything other than CPU.
CPU I use RealTemp with TjMax setup to 100 celsius.
  #43 (permalink)
Old August 28, 2008, 08:17 PM
mattlef's Avatar
Thanks :D
Okay, so I've got the NB Voltage at 1.36, and things are looking to be stable, but lol, 20 mins stable is not 6-8 hours stable.
CC-HotSpot Host
  #44 (permalink)
Old August 28, 2008, 08:18 PM
Thanks :D
20 mins is good. 1 hr is better 3 hours is great.
  #45 (permalink)
Old August 28, 2008, 08:22 PM
mattlef's Avatar
how long should i leave it for a burn in? 6-7hours?
CC-HotSpot Host
  #46 (permalink)
Old August 28, 2008, 08:26 PM
If you wish.. if you can make it to a 3 hour mark your generally good.
  #47 (permalink)
Old August 28, 2008, 08:48 PM
mattlef's Avatar
Alright, well its 40 mins stable with a blend and 30 mins stable at a small FFT in orthos, things are looking good...
Crysis still crashes but I think thats more software then anything. I'm going to try a re-install, and see if that works....
However, when Crysis crashes, it freezes... giving no bsod. Which leaves me to beleive that its possible a Ram problem again.... I'm gonna run a memtest to see whats going on, ebcause its weird that orthos blen will report nothing but then this happens.... bizzare
and Memtest just forced a reboot.... I think theres a problem with the ram lol
CC-HotSpot Host
  #48 (permalink)
Old August 28, 2008, 08:54 PM
What voltage are you running for your memory?
  #49 (permalink)
Old August 28, 2008, 08:56 PM
mattlef's Avatar
Its running at 1000mhz @2.1
CC-HotSpot Host
  #50 (permalink)
Old August 28, 2008, 09:01 PM
Then you aren't running your cpu:mem at 1:1 ... that means your running a FSB of 500 mhz to hit 1000mhz memory.
