  #31 (permalink)
Old August 28, 2008, 07:12 PM
werty316's Avatar
Why use a memory divider when you are running PC2-8000 sticks? You wouldn't have a problem running a 1:1 ratio.
I would also suggest that you increase the vcore.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
  #32 (permalink)
Old August 28, 2008, 07:17 PM
Exactly always run a 1:1 no matter what to get the best clocks and stable overclock then worry about tweaking the rest.
Personally I just don't think he's setting up his system right and ends up with a 5:6 divider.
  #33 (permalink)
Old August 28, 2008, 07:36 PM
mattlef's Avatar
Heres what I'm running now, and trying to adjust timings for my ram.
FSB: 500 x 8
Vcore: 1.45
DRAM:FSB- 1:1
Dram : 2.1
The issue is that when I run an Orthos CPU/Ram blend stress test, the effin computer freezes.... due to timings? I'm using some I got from Greg.... just trying to do some fine tuning
Edit- CPU looks like it might be stable, Stressubg well with Gromacs core....
Loading at aprox 50C/Core
Urgh, My NB Volt is on auto.... should i throw this to around 1.32
and I have my PCIE at 100.... is this right?
CC-HotSpot Host
YouTube Instagram Twitter
  #34 (permalink)
Old August 28, 2008, 07:40 PM
FSB: 500 x 8
Vcore: 1.45
DRAM:FSB- 1:1
Dram : 2.1
SmallFFT fo CPU
Blend for RAM
  #35 (permalink)
Old August 28, 2008, 07:42 PM
mattlef's Avatar
Originally Posted by enaberif View Post
SmallFFT fo CPU
Blend for RAM
so if my blend freezes, then I know is the ram timings correct?
CC-HotSpot Host
  #36 (permalink)
Old August 28, 2008, 07:44 PM
If blend freezes yes you may perhaps have a problem with your memory.
So try timings like 5-5-5-15 or even 5-5-5-18
  #37 (permalink)
Old August 28, 2008, 07:46 PM
mattlef's Avatar
Right now, I'm using 5-5-5-15 timings I got from Greg... with some minor tweaks. I'm going to run a Blend and Memtest in a few...
Should I value the NB Voltage?
Would pcie be a problem at 100?
CC-HotSpot Host
  #38 (permalink)
Old August 28, 2008, 07:47 PM
PCI-E MUST be set to 100 to prevent it from going up and causing issues later.
Yes you can adjust your northbridge which can help with stability of memory.
  #39 (permalink)
Old August 28, 2008, 07:53 PM
mattlef's Avatar
What would you reconmend... I'm gonna try 1.32 but I have a feeling it might need to be higher
CC-HotSpot Host
  #40 (permalink)
Old August 28, 2008, 07:54 PM
Try 1.32 .. you could even try 1.4 if you wanted... just keep an eye on your NB temps.
