  #21 (permalink)
Old August 27, 2008, 10:20 PM
Dashock's Avatar
yea thats exactly what i have mine set as but 1.41 volts and 2.1 for the ram.
Intel Xeon E3110 @ 3.0ghz
XFX 8800 GT Alpha Dog Edition
Asus P5Q-E
Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v
OCZ 600W GameXstream
Seagate 7200.11 500gb
Seagate 7200.10 320gb
Antec Spot Cool
Logitech X-230
Samsung 32" 720P HDTV
Coolermaster Cosmos S/
  #22 (permalink)
Old August 27, 2008, 10:28 PM
You should still get more than 4.0 :)
  #23 (permalink)
Old August 27, 2008, 10:30 PM
Dashock's Avatar
yea i should im just priming 4050 right now so far soo good both cores are at 57,58 respectfully hopefully thats good?
Asus P5Q-E
Antec Spot Cool
Logitech X-230
  #24 (permalink)
Old August 28, 2008, 07:05 AM
mattlef's Avatar
I was trying those timings and bios settings... Memtest showing errors, I'm going to go back to stock clocking and run memtest again, cross my fingers that this ram is getting angery and isn't bad ram.
I'm running this:
FSB: 445 x 9: 4005mhz
Vcore: 1.42
DRAM Freq: 534.0mhz
FSB:DRAM: 5:6
Timings 5-5-5-15
Command Rate: 2T
Edit- I think the boards sensors are fubar'd up. Its showing (through everst) a cpu temp of 123C lol, and a few seconds ago -120C yet realtemp is showing 40-42 /core using a 97 TjMax
My Rig:
Motivate TJ07
Check out my Build log!!!
Motivation: Sponsored by Galaxy
Upcoming Changes/Upgrades:
Check the build-log for more
  #25 (permalink)
Old August 28, 2008, 07:15 AM
I'm running this:
Vcore: 1.42
DRAM Freq: 534.0mhz
FSB:DRAM: 5:6
Timings 5-5-5-15
Command Rate: 2T
Make sure your FSB strap is set to 333 not anything higher.
  #26 (permalink)
Old August 28, 2008, 07:17 AM
mattlef's Avatar
oops, yea, my strap is at 333.
I'm running memtest again, and so far so good.
LOL wtf!
This is kinda funny... I wonder if my mobo's sensors are screwed up because this keeps on happening... (in both everst and bios) Mobo temps show at either extreme 120C or -120C
and the same with the cpu at times.
My Rig:
Motivate TJ07
  #27 (permalink)
Old August 28, 2008, 08:41 AM
mattlef's Avatar
Actually, I'm going to try something else. I'm thinking of uppin the FSB to 500 changing the multiplier to 8. Would I have to have the strap at 333 as well, or can I bring it up to 400?
What Vcore and NB voltages should I use?
____________
GOT IT!!!!
FSB: 500 x 8
Vcore: 1.38
Dram:FSB - 1:1
Timings: 5-5-5-18 (going to tighten after stress tests are done... looking for some timings as we speak.
My Rig:
Motivate TJ07
  #28 (permalink)
Old August 28, 2008, 10:22 AM
mattlef's Avatar
okay this is actually starting to worry me.
I'm doing the Orthos Stress test and my "cpu" sensor in Everst jumped to 123C but realtemp is showing the cores at 50C each on load.
here is the pic
My Rig:
Motivate TJ07
  #29 (permalink)
Old August 28, 2008, 07:02 PM
mattlef's Avatar
Wow, okay...
so I guess my overclock wasnt as stable as i thought... memory errors when memtest (sometimes) and Games like crysis crash and hang (I think this is as well due to the ram clock)
Here's what I have it at now:
FSB: 440 x 9
Vcore: 1.34
DRAM:FSB 5:6
FSB Strap 333
DRAM Voltage: 2.1
Any Suggestions, because I'm at a loss... I really want to get to that 4.0 Stable clock, and I think the Mushkin Ascents are holding me back a little bit
My Rig:
Motivate TJ07
  #30 (permalink)
Old August 28, 2008, 07:04 PM
Why is your ram running at 5:6? You need to set your memory to be running at DDR2-800 or so
You'll want to increase your vcore to 1.42 for stable 4.0 or higher.
