  #91 (permalink)
Old September 2, 2008, 06:25 PM
Originally Posted by enaberif View Post
Was like that with my p35 and now is like it with my P45
Either you have had a couple craptastic mobos that somehow don't support remapping, or you haven't gone & found the setting to turn it on.
You'll get a nice little surprise when you get it enabled ;)
Gigabyte X58A-UD3R | i7 930 | Corsair H50
G.Skill RipJaws 4x2 GB DDR3 | HIS Radeon HD 5870
3x Intel X25-M 80 GB RAID-0; OCZ Agility 120 GB | Samsung SH-S243D
Corsair HX1000 | Dell 3007WFP & Samsung 204T | 7 Ultimate x64
  #92 (permalink)
Old September 2, 2008, 06:30 PM
SugarJ's Avatar
Hmm. My remapping option is on, but because this mobo is a combo DDR2/DDR3 board, the max DDR2 memory is 4GB. I'm wondering if that is limiting the remap with DDR2 memory. There physically isn't another trace on the board, so it can't physically address higher than 4GB addresses. Therefore, the PCI cards memory addresses must remain below the 4gb barrier. And I lose .75 GB of useable memory.
  #93 (permalink)
Old September 2, 2008, 06:35 PM
Ugh...makes sense, but that's not particularly ideal.
I guess that's the price you pay to get DDR2 & DDR3 support on one board :(
  #94 (permalink)
Old September 2, 2008, 11:02 PM
Abit IP35-Pro doesn't have memory remap and showed 3.7
Biostar I45 has memory remap and IS turned on and shows 3.7
Neither of these boards are craptastic thanks.
  #95 (permalink)
Old September 3, 2008, 06:47 AM
I can't agree with that, but if you don't mind your RAM being stolen by crappy bios engineering, by all means ;)
Just don't assume that's the case for all people, as it's not.
Though it seems like it's more common that i thought :(
I know Asus & DFI & Gigabyte do it right...Abit & Biostar don't?
Good to know...
