Old August 27, 2008, 12:05 AM
Default Guides for Overclocking E8400 w P5QL Pro mb
Just looking for some beginners guides or suggestions on overclocking for my E8400. Don't want to overclock too high so that it wrecks the chip or other things. Will overclocking shorten the life of components? I'm not wanting to go crazy here, maybe like 3.4>3.6ghz stable.
Specs
E8400 3.0ghz
P5QL Pro mb
8gb Kingston PC6400 ram
Nvidia 280GTX
Thanks
Old August 27, 2008, 12:07 AM
Specs
E8400 3.0ghz
P5QL Pro mb
Nvidia 280GTX
Thanks
3.4 or 3.6 should happen without anything.
You'll just need to go into your bios and set it up so you set your FSB to say 400 fsb and make sure your memory is set to 1:1.
Not an expert on the bios but that's all it should take.
Old August 27, 2008, 12:09 AM
Ok, I'll go fiddle around in there for a bit and see what happens. My cd-rom drive isn't being detected so I have to go in there anyways because I think I disabled it when I was booting off the vista disc by accident.
Old August 27, 2008, 12:54 AM
I found out how to change the FSB but I don't know where to find the Memory 1:1 that your talking about.
Also my DVD Drive isn't working. Windows says the driver is missing.
Old August 27, 2008, 01:02 AM
Overclocking help. E8400 & P5QL Pro - Core system - PC Hardware
Under AI Tweaker Menu
Set FSB Frequency to 400mhz
Set PCIE Frequency to 100
Set FSB Strap to Northbridge to 400mhz
Set DRAM frequency to 400mhz
FSB = CPU
DRAM = Memory
Old August 27, 2008, 05:39 PM
So I did what you said. Just want to make sure this looks right.
[img=http://img262.imageshack.us/img262/7029/ocdvd1.th.jpg]
Old August 27, 2008, 05:57 PM
voltage is a tad low. CPU-Z is showing 1.2v what does HWMonitor report?
Old August 27, 2008, 10:21 PM
I had some weird stuff happen when I oc'd it so I turned it back. I'm not sure what the problem was but when I was trying to play Stalker and when I tried to install something I got some crazy blue screen then it restarted. Not sure if its related
Old August 27, 2008, 10:27 PM
Mushkin Ascent 8000(100mhz) and E8400
refer to my post there.. it'll be similar.
Old August 27, 2008, 11:15 PM
I actually think it might have been a bad Vista install. I remember looking at task manager when I was doing something and it listed like 8 processes. Kinda weird right? So I reformated once again and Installed Vista for probably the 5th time in 3 days and now I have like 42 processes showing up.
