  #21 (permalink)
Old August 27, 2008, 10:39 AM
memory will be called ddr2 or something.
  #22 (permalink)
Old August 27, 2008, 11:02 AM
SugarJ's Avatar
I think it's vDimm in HW monitor for memory voltage.
  #23 (permalink)
Old August 27, 2008, 02:18 PM
1Tanker's Avatar
Originally Posted by voklskier4452 View Post
okay I am gonna step down to 3.85ghz and see how that goes... But I took both of your advice.. I raised the northbridge to 1.45 and the vCore to 1.425. That gave me 1.4v in CPU-Z during idle and around 1.36-1.37 under load. I don't see a reading in HWmonitor for vDDR.. care to elaborate on which one you want?
Shows as DDR on mine:
  #24 (permalink)
Old August 27, 2008, 03:54 PM
Okay well I don't see any of those readings these are what I get.
Cooler Master ATCS 840 (black)
Core i7 920 with DD MC-TDX
Asus P6T
EVGA gtx285 (single for now)
Patriot Viper PC3 12800 3x2gb
WD 500gb 7200rpm
WD raptorx 150gb 10000rpm
Corsair 1000HX
Vista Ultimate 64bit
Klipsch pro media 2.1 speakers
  #25 (permalink)
Old August 27, 2008, 04:41 PM
do you have the proper chipset drivers installed?
something isn't right there.
  #26 (permalink)
Old August 27, 2008, 05:34 PM
I am going to download the newest chipset drivers from EVGA for my board (780i) So we will see if that helps somewhat..
Asus P6T
WD 500gb 7200rpm
Corsair 1000HX
  #27 (permalink)
Old August 28, 2008, 03:14 PM
I installed the latest mobo drivers directly from EVGA. They don't seem to have any effect on stability or the readings given from HWmonitor. I ended up accidentally running prime95 all night and 1 core stopped after 33 minutes and the other went for about 18 hours till I quit prime95. Do you think it could be a problem with my e8400?
Asus P6T
WD 500gb 7200rpm
Corsair 1000HX
  #28 (permalink)
Old September 1, 2008, 01:36 PM
alright so since their does not seem to be anymore help coming I guess i will just sit on my 3.6ghz oc
Asus P6T
WD 500gb 7200rpm
Corsair 1000HX
