  #21 (permalink)
Old August 28, 2008, 10:20 AM
3.0charlie's Avatar
Originally Posted by enaberif View Post
Yup! I want the Biostar so we'll have to see what my budget entails.
Basically whats happening is I get a BSOD and the error is MACHINE_EXCEPTION_CHECK.
Now they say this could either be a faulty cpu or a motherboard problem.
Of course I have no other motherboard to test.. so I'll probably run this guy back at stock to see what happens.
The other strange thing is F@H works fine until about 7% then it dies every time.
F@H is the toughest Son-of-a-Gun software for computer stability, especially Ram. Check and loosen them timings - it's usually that.
Hydro-Quebec is salivating...
  #22 (permalink)
Old August 28, 2008, 11:38 AM
Infiniti's Avatar
Originally Posted by yycraven View Post
You might have a stuck sensor, cause my temps are way lower.
On ilde mine is at 32C and on load its at 50C
here is a pic for yeah
Hmm.. I wonder if I can get my chip RMAed for that, because I bought it less than two weeks ago.
  #23 (permalink)
Old August 28, 2008, 12:21 PM
yycraven's Avatar
Well if you do RMA it you might get the new E0 stepping.
Where did you buy it maybe they can exchange it for you.
  #24 (permalink)
Old August 28, 2008, 12:32 PM
Nice going there bro, 4+ghz with no effort, really nice ...
Damn all you guys with E8400's stop posting your screenies, and OC results, ur all tempting me to get my rig done ASAP. *breaks keyboard at work*
I "had" all the equipment for water.. I just didn't do it and sold it off :P
Yeah until I encouraged him to do it all again, maybe he was too tempted while helping me with my setup :P :D..
  #25 (permalink)
Old August 28, 2008, 12:39 PM
Infiniti's Avatar
I got it at Anitec. Maybe they can exchange it, but I'll need to find the receipt.
  #26 (permalink)
Old August 28, 2008, 01:00 PM
yycraven's Avatar
They should have you on there system,that should be good enough.
If you can not find your receipt.
  #27 (permalink)
Old September 5, 2008, 06:31 AM
zlojack's Avatar
These chips are pretty good.
I got one from Canada Computers batch #820A596 and it wasn't great. 1.36v for 4.3GHz but anything above that no matter what was not stable in Linpack or Orthos no matter the voltage. I think it was just a bad individual because I've seen others of the same batch do better. I returned the chip due to the stuck sensors (they were stuck at 40*C) and I got a Q820A597 and this one is a sweetheart. So far I'm at 4.4GHz at 1.34v and IntelBurnTest stable for 5 runs. It's now running Orthos at home so we'll see how it does when I get home this evening. It's a bit warm for my tastes, but I think I need to re-seat my Fuzion, as I'm pretty sure I applied too much TIM.
  #28 (permalink)
Old September 9, 2008, 09:35 PM
returned mine and got the same one back again :(
  #29 (permalink)
Old September 9, 2008, 09:39 PM
zlojack's Avatar
What's the batch number?
Mine ended up needing a bit more to be stable at 4.4GHz (1.36v) but now it's doing just fine!
  #30 (permalink)
Old September 9, 2008, 10:14 PM
Same batch numbers across the two Q820A306
