Old August 19, 2008, 09:15 PM
Dashock's Avatar
Originally Posted by enaberif View Post
I "had" all the equipment for water.. I just didn't do it and sold it off :P
Must have been costly still have sum left over components when i first build my loop im happy though it has costed me a pretty penny but temps in my room are welll below and i can actually close the door in my room and not worry aboot having a sauna in less than 2 hours.
Anyways once i set everything up ill try to beat yea record mate! :p maybe i should start whining aboot the E0 stepping j/k lol
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old August 27, 2008, 10:47 PM
So I can get this thing Orthos stable at 4.4ghz no problem.
I try running F@H and BOOM! BSOD.
Time for a new board.
Abit IP35 Pro will be up for sale possibly.
Old August 27, 2008, 11:03 PM
SugarJ's Avatar
Gonna try a Biostar Tpower I45? Or something more exotic?
Old August 27, 2008, 11:05 PM
Yup! I want the Biostar so we'll have to see what my budget entails.
Basically whats happening is I get a BSOD and the error is MACHINE_EXCEPTION_CHECK.
Now they say this could either be a faulty cpu or a motherboard problem.
Of course I have no other motherboard to test.. so I'll probably run this guy back at stock to see what happens.
The other strange thing is F@H works fine until about 7% then it dies every time.
Old August 28, 2008, 12:04 AM
Infiniti's Avatar
Hmm, I was just wondering, what were your temps for your E8400 when OCed to 4.2? My temps are 50ish on idle and 70 load when OCed to 4... And I'm on water cooling too.
Old August 28, 2008, 12:07 AM
Your temps are out to lunch. I had less than 42 idle with my true 120 and about 60ish on load.
Old August 28, 2008, 12:09 AM
Infiniti's Avatar
Hmm... Would the temp problem be related to.. bad temp sensors on the chip? Because I have a triple rad with the Fuzion v-2, so I don't think theres a problem with my WC..
Old August 28, 2008, 12:12 AM
Hard to say but 50ish idle is high.
  #19 (permalink)
Old August 28, 2008, 05:43 AM
ebdoradz's Avatar
your temps are way off
i have a triple rad with a Fuzion V2 on the cpu, and a GFX fuzion v2 on my video cardv.. even if its a amd cpu my temps are about 40C lower then yours
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 512mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
  #20 (permalink)
Old August 28, 2008, 10:16 AM
yycraven's Avatar
You might have a stuck sensor, cause my temps are way lower.
On ilde mine is at 32C and on load its at 50C
here is a pic for yeah
