<~----> Temperature Thresholds??? - Hardware Canucks
Old April 18, 2007, 01:12 AM
mattydies's Avatar
Default Temperature Thresholds???
Hello I wanted to ask about some SAFE temperature thresholds.
I Know that these things vary from Chip to chip and what not, but I am looking for a good general idea.
I WILL be over-clocking my "new" computer (new MoBo, Vid Card and CPU) after the new PSU arrives and I iron out a couple things.
I have an NVIDIA 6200 Card, 256 Meg - 8X AGP. What is a safe threshold for the GPU? A friend of mine recommended "cool bits". I have it installed but have not yet over-clocked (waiting mainly for a PSU).
My NVIDIA Force Ware says That the GPU's "Core Slow Down Threshold" is set at 145 Degree's Celsius. IT DOES NOT appear to be adjustable. Does anyone know how I can adjust this? And what is a realistic SAFE HEAT level?
I have a Pentium D 915 CPU. 4 megs cache and an upgraded Heat Sink and Fan. Arctic Silver 5. I want to know what is a SAFE MAX Heat level?
Also What is a Safe Main-board Temperature? I will likely be upgrading hte cooling for the North Bridge (which has a heatsink) and South Bridge Chipsets.
I have HDD Coolers on both of my HDD's. What is a Safe Temp for them?
Thanks in advance. This place is a HUGE Help :)
Old April 18, 2007, 04:27 AM
Babrbarossa's Avatar
I'll look around for the pentium D, but you really don't need to worry about you HDs - especially if you have a cooler for them. (unless you're working in and oven).
If you're buying aftermarket NB and SB cooling for your mobo, you won't have to worry about it either (my 680i is rated for 100 degrees C)
For the GPU, I'd say don't let it go over 80.
psst, wanna see my binder?
Old April 18, 2007, 10:11 AM
mattydies's Avatar
Thanks for the Info :)
It is much appreciated
Old April 18, 2007, 10:26 AM
The peniutm d's run very hot- it's not easy to keep the temps down on them. The MAX max is 70, but you should definately keep it under 63C under load- and should aim for under 60- that's my take on it.
EDIT: Reading a little more, I've found some opinions that say it's ok to go up to 70C- so I dunno- judgement call?
Old April 18, 2007, 10:48 AM
Misoprostol
Guest
Posts: n/a
I'd say if you can keep a Pentium D under 60 when overclocking you'd need water cooling, so 70 is probably ok with air, and I'd probably be ok even with 75 on those chips. I'm pretty sure they don't throttle until they get even higher than that.
Old April 19, 2007, 01:08 AM
mattydies's Avatar
EDIT - I seem to have an issue with the trail version of "HMonitor" It seems to be showing the TEMPERATURE @ HALF of its true level. Something with my Pentium D?
Can I fix this?
IS there another program I could try?
Thanks again for the help guys
Confusing temperature readings magictorch CPU's and Motherboards 7 November 30, 2007 04:47 PM
Max temperature Vinnie Overclocking, Tweaking and Benchmarking 4 November 28, 2007 08:08 PM
Way too many temperature readings! Mibs Water Cooling 2 August 4, 2007 12:00 PM
Fan speeds, temperature... omgwtf CPU's and Motherboards 21 May 25, 2007 04:58 PM
C2D temperature woes Babrbarossa CPU's and Motherboards 35 April 1, 2007 12:39 PM
