Old August 15, 2008, 03:45 PM
Default OC E8400
Overclocking E8400
MOBO:: ASUS P5K Deluxe Wi-Fi
RAM:: Mushkin 800Mhz Enhanced DDR2
COOLING:: AIR Thermaltake V1, Stock RAMSINKS.
See, I've got myself to 4.0GHZ in a really warm room hitting maximums of 60-62 on load and around 39-38 idle.
Anyone think I could go a little further?
Or If I can't do that much.
I'm willing to upgrade my heatsink if anyone has any grand suggestions.
Much appreciated.
Dave
Old August 15, 2008, 03:49 PM
3.0charlie's Avatar
Yes, probably.
It may happen.
Grand suggestions? Water-cooling, phase-change, ln...
What I'm saying is that it's always possible to push a CPU a little more: add more Vcore, better cooling...
You have to try to know, and decide if you wish to upgrade the cooling method.
Hydro-Quebec is salivating...
Old August 15, 2008, 03:53 PM
Yes, probably.
It may happen.
Yeah, see I have around 200$, and to be honest, air cooling is dirt cheap these days.
Water cooling, ( blocks.. equipment.. ect. ) cost around 100$ EACH.
Like, a CPU block isn't it around like.. 100$?
Plus the pump and the rest? ( 200 more dollars.. )
Much more efficient though..
Old August 16, 2008, 12:40 AM
1Tanker's Avatar
Overclocking E8400
Much appreciated.
Dave
You can give us all the pertinent voltages in BIOS...we might see something on the low side. Although your HS/F isn't the latest and greatest..your temps seem fine. A TR-U120Extreme will cost you $60($50 on sale), plus a good 12cm fan, if you don't have one..but there's no guarantee it'll give you more. See if you can get the model #/timings and or voltage of your RAM for us. Also, what is your aim...a 12hour++ Prime-stable overclock, or a very-stable overclock that will probably only crash in Orthos/P95/OCCT...or, an overclock that's awesome..will game, etc.... but is on the ragged edge of stabiltity?
Old August 16, 2008, 10:38 AM
yycraven's Avatar
I use a CoolerMaster Hyper 212 on my E8400, have it at 3.9GHz idle is 29C to 31C and load is 49C
If you can't get a Hyper 212, get the TR-U120 Extreme.
my Core V is 1.28V so you should be able to go higher.
