Old August 12, 2008, 08:02 PM
mattlef's Avatar
Default Overclocking E4500 and Ram...
Hey guys,
I'm just wondering what you think I could to to improve on? I'm currently running great load and idle temps at 3.1ghz (24idle 39load)
However, I'm using OCZ DDR2 667 Vista upgrade ram(4gig kit) and because of the oc, its at 940mhz, 2.0 volts.
With the attached pics... do you have any advice to somehow get me up to around 3.3 3.4 stable? I can only get 3.1-3.2 stable for whatever reason.
Specs in my sig.
My Rig:
Motivate TJ07
Check out my Build log!!!
Motivation: Sponsored by Galaxy
Upcoming Changes/Upgrades:
Check the build-log for more
Old August 12, 2008, 08:08 PM
3.0charlie's Avatar
Those 65nm chips can handle upto 1.50V Vcore easily. But you'll probably reach the temp. max first, which is 60C under load. Those are my 24/7 conservative numbers, which I've used with all my 65nm chips (E2140, E4400, E6400, E6420, 2x Q6600).
Old August 12, 2008, 08:24 PM
mattlef's Avatar
so If I bump my Vcore to around 1.50 I should be alright to increase my fsb to get that 3.4? Would my ram hold me back, because I'm wondering if I'm in need of an upgrade with 667 clocking in around 900+, or should I play it safe and keep what i got?
My Rig:
Motivate TJ07
Old August 12, 2008, 08:33 PM
3.0charlie's Avatar
Loosen the timings, raise the Vram (if you can) and go for it; my XP2-5300s did 900+ Mhz easily. Try it, can't break it! But always check those temps: max. 60C under load.
Old August 13, 2008, 11:08 AM
mattlef's Avatar
I tried working with my timings a bit, but to no avail... I can't adjust the Vram. The issue i have however, is that I cant seem to get it past 3.25. It'll post, but when loading into windows it'll BSOD with a hardware failure. Am I pushing the ram to hard? cause thats the only reason i can see it doing that as CPU temps are relitivly stable around 28-30idle in bios.
My Rig:
Motivate TJ07
Old August 13, 2008, 11:27 AM
CPUs have a threshold that you simply can't get around no matter how hard you try.
Old August 13, 2008, 11:32 AM
mattlef's Avatar
hrm,
I guess Its time to upgrade my cpu :S
My Rig:
Motivate TJ07
Old August 20, 2008, 10:53 PM
I would upgrade your RAM as well if you are going that path. You can see that you have a 10:6 ratio (or 5:3) and that will be causing your RAM to create a bit of a bottleneck.
Q6600@3.15Ghz|CNPS9500|GA-EP45T Extreme|GSkill 2GB 1333MHz|Sapphire 4850|OZC GameXtreme 700|XP64
