Old April 14, 2007, 05:31 PM
Babrbarossa's Avatar
Default e6400 @ 3.84Ghz evga 680i
This new p27 Bios has turned this board into an absolute overclocking BEAST. I went from a maximum 3.6GHz with p26 to 3.84GHz (Orhtos stable 1.5hrs)- The new BIOS seems to have broken the FSB wall of 450 that many have been finding. I think I could probably go a fair amount higher with some high volume fans - I'm running whimpy 11.2 cfm fans on my rad right now. I know the CPU is the luck of the draw, but my e4300 went from 3.3 to 3.5 with the new bios.
Old April 14, 2007, 05:39 PM
It's idling fairly warm- I wish I had some faster fans to cool it- I bet I couls break 3.9
Old April 14, 2007, 05:51 PM
The funny thing is that recently, I've had someone accuse me of having a 'ghetto' system- They had a 700USD dual loop (two PA120.2 thermochills) watercooling system and a e6700, and their overclock was 3.6.
Old April 14, 2007, 06:00 PM
sswilson's Avatar
Those look like some mighty fine load temps to me. Is there a difference between using TAT for load & running prime95 or Orthos?
What's normal vcore for those? Is CPU-Z reporting fairly accurately?
Old April 14, 2007, 06:09 PM
No- CPU-Z can't read the voltages at all- mine are set to 1.6 right now. My stability is tested using Orthos for at least one hour + all my benchmarks- only because I don't have much time to test every setting for the usual time- I will clearly state this in the review- I imagine that I would be stable at 1.53 at 3.8Ghz- we'll see.
If you use TAT to load at 100%- it is insane- the load created by TAT is far beyond any benchmark or anything like Orthos- If I ever use TAT to stability test, it's at 75% or 80% load.
Old April 14, 2007, 06:14 PM
Deathspawner's Avatar
Grats on the huge increase. Sadly, upgrading to the P27 still left the 450FSB limit for me. I seem to be the last one with this problem!
Techgage.com | Editor in Chief
Intel Core 2 Quad Q9450 @ 3.20GHz, ASUS P5K Premium WiFi-AP, OCZ 8GB PC2-6400, EVGA GTX 285 1024MB
Seagate 500GB, 750GB & 1TB, Pioneer 22x ODD, Corsair 1000HX, Thermalright Ultra-120, CM Storm Sniper
Dell 2408WFP 24", ASUS Xonar Essence STX, Ultrasone PRO 750, Gentoo Linux (KDE 4.4, 2.6.32 Kernel)
"Take care to get what you like, or you will be forced to like what you get!" - H.P. Baxxter
Profiles: Last.fm | Xbox Live | Steam
Old April 14, 2007, 06:22 PM
Misoprostol shares your grief!
Old April 14, 2007, 06:43 PM
sswilson's Avatar
I was reading it wrong.... I thought those temps were at load.
What are your load temps?
Old April 14, 2007, 06:45 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Thats a hellofa CPU, if you get bored w/ it PM me. ;) GJ.
Old April 14, 2007, 11:56 PM
werty316's Avatar
Holy crippers that is a nice overclock
Great job
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
New Bios for evga 680i just released! Babrbarossa CPU's and Motherboards 22 October 8, 2007 10:59 AM
evga 680i , which one ? Jim CPU's and Motherboards 3 August 28, 2007 11:03 AM
e6400 @ 6.84GHz LOL!! Babrbarossa Overclocking, Tweaking and Benchmarking 11 April 28, 2007 10:39 AM
e6400 and NVidia evga 680i 775 safe overclock Babrbarossa CPU's and Motherboards 28 February 1, 2007 03:14 PM
