Old November 1, 2006, 06:22 PM
Gav's Avatar
Gav Gav is offline
Administrator
Default Benchmark/Stress Test Programs
I found a good list of Benchmark and Stress-test programs here:
http://www.benchmarkhq.ru/english.html?/be_cpu.html
If anyone knows of any that are not on the list please list.;)
Old January 7, 2007, 12:56 PM
van's Avatar
van van is offline
"Orthos Stress Prime 95" isn't on that list, and it's a must have for dual/quad-core CPU's. It's based on the Prime95 code but with a much better UI as you don't have to open up two instances of the program to test-stress both cores.
Old January 8, 2007, 11:28 AM
Misoprostol
Guest
Posts: n/a
One of my problems with Orthos is that it takes almost as much time as 4 instances of Prime95 once you set all of the affinities. Does anyone know of a quad threaded Prime95?
Old January 8, 2007, 10:23 PM
Gav's Avatar
Gav Gav is offline
Administrator
Have you checked to see if S&M can run 4 instances through the setup? I can't remember off the top of my head.:confused:
Old February 14, 2007, 06:47 PM
Default temperature monitoring software
Does anyone here know how accurate the Asusprobe monitoring software is? Are there any tried and true temp monitoring programs out there that any of you rely on?
Old April 9, 2007, 10:59 PM
Scratch's Avatar
I've actually downloaded all of my programs from here
The Guru of 3D Download Section
and OCC has a thread for the conroes that runs dual instances here
Socket 775 Oc Competition Thread - OverclockersClub Forums
S&M Stress Test Program Gav Overclocking, Tweaking and Benchmarking 11 July 6, 2012 01:21 PM
3DMark06 benchmark sswilson Overclocking, Tweaking and Benchmarking 292 November 10, 2008 06:51 PM
New Benchmark! Prof. Dr. Silver Off Topic 11 January 15, 2008 12:51 PM
Any workarounds, hacks or programs available for HTML posting or similar effect? qwerty Troubleshooting 0 December 9, 2007 03:44 PM
Benchmark run-times Mr. Cipher Overclocking, Tweaking and Benchmarking 8 November 2, 2007 08:48 PM
