Old July 27, 2008, 07:29 PM
Level up: 42% Level up: 42% Level up: 42%
Level: 7 - 81 points to level up
Default Hi Guys
Hello can i ask about overclocking?Well hope you dont mind. Well i am new in overclocking and i played around the bios in the DRAM timings and i place the latency into 2 LOL. After that i saved and exit then it POST. There has been 1 long beep and 3 -4 beeps. I read that it either the motherboard, Power Supply or RAM. Then i turned off the computer. After that it wont even start. When i turned the pc it dont start. Well there has been some fans spin but really short time and it stops (FANS of PowerSupply and CPU HSF). I just wonderin did i destroyed the motherboard? But theres a question in my head if i destoryed the motherboard shouldnt the FAN of the Power Supply Spin even thought the motherboard is bricked?
THANKS
Old July 27, 2008, 07:33 PM
Level up: 8% Level up: 8% Level up: 8%
Level: 23 - 1,381 points to level up
Find the CLR CMOS jump and use it.
CSE: Lian-Li PC-A70
MOB: Biostar T-Power I45
CPU: Intel C2D E8600 @ 4.3ghz
RAM: 4gb g.skill pc2-8000
GPU: XFX 8800 GT Alpha Dog Edition
PSU: PC Power & Cooling 750w
Heatware: My Heatware
Old July 27, 2008, 07:49 PM
well i did that waited for about 2mins then removed the cmos battery for about 30secs. I think its the power supply though coz it should work even though the motherboard is bricked? Am i right? If i plug the powersupply the fans should work but it just spins for about a sec then it stops. And now its not spinin at all
Old July 27, 2008, 07:50 PM
You can't brick a motherboard by changing the memory timings around.
CSE: Lian-Li PC-A70
Old July 27, 2008, 07:52 PM
I see (My bad). But i think its the powersupply. coz it powers for just a sec and then power loss. Thanks
Old July 27, 2008, 09:15 PM
3.0charlie's Avatar
You set the timings too agressively. You have to:
  1. disconnect the external PSU cable.
  2. press the power switch to drain the caps
  3. remove the CMOS battery
  4. jump the CMOS header to clear
  5. install the battery
  6. connect the external PSU cable
  7. press the power switch again
Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182
HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B
Old July 27, 2008, 10:01 PM
I did that with no avail :D. anyway its a very old rig 1998. I think the powersupply failed coz i believe that if i plug the powersupply in the AC outlet it should work(the Fan spining), but theres no fan spining. I guess it the powersupply.
Correct me if im wrong
Old July 28, 2008, 06:39 AM
3.0charlie's Avatar
You have to jump the PSU in order to start it alone. Plug a few fans at the Molex connectors, and jump pins 4 (Green wire) and 6 (black wire). That's looking straight on at the connector, with the safety tab on top. Both pins are on the top row.
Then flip the PSU switch. Works?
Old July 28, 2008, 09:08 AM
ebdoradz's Avatar
Level up: 53% Level up: 53% Level up: 53%
Level: 14 - 277 points to level up
you may also try a 24hrs clear cmos.
it have save my ass more then once on my both DFI rigs ....
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.8Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Corsair 620W PSU / 2*Seagate 80Gb
DFI LP Nf2 Ultra-B / AMD Athlon XP-M 2500+ @ 2.4Ghz/ CENTON DDR400 TCCD / Evga 6800 AGP / FORTRON 450W PSU / 2* Maxtor 80GB
ASUS A7N8X / AMD Athlon XP-M 1900+ @ 1800Mhz/ Corsair XMS 2*512 / BBATI 9800pro AGP / FORTRON 450W PSU / Maxtor 80GB + 120GB
ABIT KT7A-RAID / AMD Athlon XP 1800+ @ stock/ 2*256mb PC133/ Geforce 4 mx440 / 250W PSU / Maxtor 20GB
Old July 28, 2008, 08:09 PM
thanks for replies
