LinkBack (1) Thread Tools Display Modes
  1 links from elsewhere to this Post. Click to view. #1 (permalink)
Old July 26, 2008, 09:34 PM
Default HP Pavilions and Overclocking
Ignoring the fact that the computer came loaded with useless trial software, Norton Antivirus, had a bad graphics card, and hardly any RAM, I've found one more reason to hate my HP Pavilion a1132n today. I was going to try to overclock the thing so I could keep up with software for another year or so, (I like XP, what can I say.) and noticed something strange with the BIOS. I contacted HP Customer Support where I got a scolding that reminded me of when I was 12.
The reason is computer simply may not work. Increasing the speed of a processor is not recommended: It may work, it may not. If we push the processor too hard, normally it will refuse to start up, there will be occasional crashes or some programs will not work, etc. Besides this, when it does work the first time, problems may arise later with the processor owing to three features of the electronic circuits: 1. Increase in heat
2 Electromigration: This is a rather ambiguous concept. We know that faster operating speeds cause a kind of ‘erosion’ in the processor’s circuits.
3 A change in the overall configuration of the machine
4 Machine guarantee: Overclocking the processor or changing the factory configuration of any of its internal components implies the automatic loss of guarantee.
So, considering these all HP disabled the option of Overclocking of the Processor and other components.
I don't know if this applies to all HP computers, but if it does, I have some strong advice for you all; buy a Dell.
Old July 26, 2008, 09:40 PM
Level up: 23% Level up: 23% Level up: 23%
Level: 8 - 139 points to level up
all prebuilt computers have blocked oc'ing in the bios
i had that same exact comp, and i used clockgen to OC the CPU. although i could not raise the voltages
Q6600 @ 3ghz
XFX 680i LT
2 x 2 GB OCZ 5-5-5-15
EVGA 8800GTS 640mb 650/1610/2100
Mushkin 650watt Modular
Ultra Aluminus
LG 22" Wide
G5/G15/Z-5500 Logitech
Old July 26, 2008, 09:47 PM
Level up: 37% Level up: 37% Level up: 37%
Level: 10 - 179 points to level up
Almost all OEM machines are like that. HP, Compaq, Medion, etc. To be honest I thought Dell was the same. They don't want to deal with all the RMA and warrenty problems with people killing their hardware. I've got two HPs in my home. They are my roomate's and I keep trying to talk them into getting even just cheap replacement motherboards so I can overclock them for them (I really want to try AMD o'clocking).
ASUS P5Q-E - E8400 (4GHz) - Corsair TX650W - 2xHIS HD 4850 IceQ Turbo - 2x2GB Mushkin Ascent 8000 - 2xWD 500GB - TRUE 120 - Antec 1200 - ASUS Xonar DX - Big Smile
Old July 26, 2008, 09:48 PM
Ah, thanks for clearing that up. (If you couldn't tell, I don't exactly know a lot about "oc'ing")
Old July 27, 2008, 12:16 AM
Level up: 20% Level up: 20% Level up: 20%
Level: 8 - 144 points to level up
Pretty much all pre-built computers have blocked OC'ing...the only way is to use Clockgen or some other software to do it. I have an HP comp too and I used Clockgen to OC it but the only prob is I can't raise VRAM so I'm limited by the RAM.
Antec NSK 6500 w/ TriCool intake, S-Flex F exhaust
Corsair HX520
Gigabyte GA-965P-DS3 Rev1.0 @ 500FSB
Intel C2D E6300 @ 3.5ghz 1.45V
Arctic Cooling Freezer 7 Pro
Mushkin (996576) 2X1GB HP2-6400 @ 1000mhz 5-5-5-15 1.9V
eVGA 7600GT KO @ 630/880
Seagate 7200.10 320GB
Samsung SH-162
Samsung 205BW
Logitech Media Keyboard
Logitech MX518
Old July 27, 2008, 08:51 AM
3.0charlie's Avatar
Originally Posted by CWestfall View Post
buy a Dell.
Dell does not allow oc'ing too on all their lines.
I do not recommend oc'ing on any prebuilt computer, since the installed HSFs are not made to extract the added heat output.
Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182
HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/8862-hp-pavilions-overclocking.html
Posted By For Type Date
Can i overclock an HP media center m8430f? - Yahoo! Answers This thread Refback September 19, 2008 03:04 PM
