Old July 17, 2008, 09:14 AM
Eldonko's Avatar
Hardware Canucks Reviewer
DL and flash the latest BIOS, then try again.
Hockey Mod at your service
Old July 17, 2008, 10:20 PM
Level up: 20% Level up: 20% Level up: 20%
Level: 9 - 189 points to level up
Originally Posted by jdrom17 View Post
Perhaps he needs a BIOS update?
That's about the first thing I told him to do, but it didn't fix his problem .
Lapped Intel Qx6850 @ 3.7 Ghz @ 1.4 volts
Coolit freezone elite
Asus Rampage Formula
8 Gig Gskill pc2 8000 4x2gig
HIS HD4870X2
BenQ V2400W monitor
Pc power and cooling quad 750
Old July 17, 2008, 10:23 PM
Originally Posted by Mibs View Post
What are the temperatures like when it boots at 350? Because if they are on the threshold, then pumping more voltage is not going to help. Check the cooler, a cooler that is not seated properly can have much more of an effect on the temperatures than you may think.
Temps are about 42-44 idle and won't go hotter than about 49 degrees under full load...
monitored with both, coretemp and real temp 2.60 with tjmax set to 95 degrees.
HIS HD4870X2
BenQ V2400W monitor
Old July 17, 2008, 10:25 PM
Originally Posted by enaberif View Post
1) Take load line calibration off.. thats BAD
You really think it is !? Got my OC rock solid stable with it enabled @ 1.4 volts...see my sig.
HIS HD4870X2
BenQ V2400W monitor
Old July 17, 2008, 10:31 PM
Originally Posted by 1Tanker View Post
I assume your sentence was for me. I know that not all clock the same... but i haven't heard of an E8400 that won't run 3.6(have you?),unless the mobo has no O/C options. In that case a pad-mod to 400MHz would likely work anyways.
Sorry if I sound ignorant, but as you may have noticed, english is not my first language . So that being said, what do you mean by " a pad-mod to 400 Mhz " ???
HIS HD4870X2
BenQ V2400W monitor
Old July 17, 2008, 11:32 PM
1Tanker's Avatar
Level up: 25% Level up: 25% Level up: 25%
Level: 13 - 363 points to level up
A pad-mod is the same as a pin-mod(which were done on non LGA-775 CPU's) It's a mod where you trick the motherboard (by way of the CPU) into thinking that the default FSB is different than it really is. So, on the E8400, the default speed is 333MHz with a 9x multiplier. By connecting the right pads(pins), it will set the default FSB as 400MHz...meaning the motherboard will "see" the CPU as a stock 3.6GHz(400x9). This generally works better on lower-end CPU's that start out with a "low" FSB of, say, 200MHz..or 266MHz. If the Cpu can run at the modded clock-speed with stock vCore, then it should work..assuming the new speed isn't beyond the chips reach. If it can't run the new speed at stock vCore, you can do a vCore mod(using the same method as the pad-mod, but joining different pads/lands/pins )... or just forget it if you don't want increased vCore. Many, but not all, E8400's can run @3.6GHz with stock voltages..so this would work... but realize that many won't, and will need a vCore-mod.. or have to be left at the stock speed.
Here's the mod
Here's The vCore-Mod
GL
Tanker
Old July 18, 2008, 12:21 AM
Level up: 7% Level up: 7% Level up: 7%
Level: 23 - 1,386 points to level up
Consider loan line like a damn to a river.
Too much pressure can build up and the dam can fail.. same thing with a cpu.
vdroop is there for a reason.
CSE: Lian-Li PC-A70
MOB: Biostar T-Power I45
CPU: Intel C2D E8600 @ 4.3ghz
RAM: 4gb g.skill pc2-8000
GPU: XFX 8800 GT Alpha Dog Edition
PSU: PC Power & Cooling 750w
Heatware: My Heatware
Old July 18, 2008, 06:45 AM
Here's the mod
Thanks for the explanation... but I don't think he'll go that way... sounds a little risky to me
I see ! so now you convinced me to disable it... hope my system will remain stable !?
By the way, I haven't heard of my friend since I started this thread... I should see him today, so as soon as I have some inputs on what's going on with his OC, I' ll let you guys know. In the meantime, I'd like to thank you all for your concern...
HIS HD4870X2
BenQ V2400W monitor
  #19 (permalink)
Old July 19, 2008, 12:20 PM
Ok, here's everything he did :
  • updated bios to latest version ;
  • boosted cpu voltage to 1.35 to see if it boots ;
  • Somethings he didn't do, is try with only 2 gigs installed and re-seat his hsf ( guess he's too lazy ).
Right now, he's been running Prime95 (large ffts ) stable for 3 hours with these
settings :
  • cpu voltage @ 1.35 ;
  • FSB @ 435 Mhz ;
  • DRam @ 1451 Mhz ;
  • Cpu ratio @ 9 ( gives him a whooping 3.9 Ghz )
  • Everything else @ auto
I was just wondering if this Ram frequency seems safe to you ( I have to say he has the corsair Ram cooler installed ). What I think he should do to be sure, is run a "blend" test in Prime, just to be sure... What do you guys think ???
Thanks in advance !
EDIT: I just touched is Ram, and it runs cool as a cucumber ;)... so I guess it's ok. Anyhow, any opinions would be appreciated...
HIS HD4870X2
BenQ V2400W monitor
