Old April 10, 2007, 12:10 AM
Scratch's Avatar
Level up: 92% Level up: 92% Level up: 92%
Level: 12 - 33 points to level up
Default OCCT Stable 1/2
Upped the voltage a tad and decided to make the push for 3.6 stable :)
EVGA 680i, Q6700 @ 3.3Ghz 1.3v, 3x WD 160GB , 2x2GB Mushkin Redline pc8000 @ 1000mhz CL5-5-5-15 2t
1x EVGA 8800GTS 640MB @ 651/1525/1003mhz, Silverstone Zeuss 750w PSU,
CoolIt MTec Freezone Elite CPU Cooler, SilverStone Tj09 case, Dell 2407WFP Monitor
Old April 10, 2007, 06:15 AM
Babrbarossa's Avatar
Super Moderator
Nice oc- what is your voltage now?
Building: ASUS P6T X58// i7 920 // SLI evga 260GTX 216SC// 3X2GB Patriot Viper DDR3-1600// Antec TP Quattro 850w // CM Stacker 830
Water Cooling: Apogee GTZ// 2X evga HC16 GPU block// HW Labs Black Ice GTX Xtreme 360 // Swiftech MCR220 // Swiftech mcp655 pump
HTPC: Asus Commando // e6400 @ 3.4 // Crucial Ballistix PC2 8000 // evga 260GTX 216SC// LG super opti-blue HD optical drive// DVB clone PCI satellite receiver//OCZ GXStream 700w // ACFP7 CPU cooler // Antec p180
Old April 10, 2007, 09:56 AM
Patriote's Avatar
Level up: 10% Level up: 10% Level up: 10%
Level: 17 - 721 points to level up
Nice Oc - 3.6Ghz is what i use for 24\7 Use.
What voltage your running through the chip now ?
• - EVGA 680I A1
• - QX6800ES G0 @ 3.95Ghz
• - SLI BFG 8800GTX @ 626Mhz \ 2000Mhz
• - 4GB G.SKILL F2-6400PHU2-HZ @ 1000Mhz
• - Ultra X3 1000 Watt
• - X-FI XtremeMusic \ Klipsch Promedia 2.1 THX
• - WD RaptorX 150GB \ WD500GB \ WD Caviar 250GB
• - MountainMod U2-UFO Black Powder Coat
• - Dell UltraSharp 24''
Loop #1 : D-Tek FuZion - 2x MCW30 - Cyclone Res - MCP355 w/ Petra's Top - PA120.3 - Tygon
Loop #2 : 2x Ek-FC 8800GTX - Ek 150 Rev.2 - MCP355 w/ Petra's Top - PA120.2 - Tygon
Old April 10, 2007, 12:34 PM
Scratch's Avatar
well...that would all depend on what utility you wish to believe lol
I have it set at 1.575v but it reports it as 1.54v
Bios Monitor reports it as 1.53v
Everest reports it as 1.55v
CPUZ won't acknowledge it...
I simply keep increasing the voltage until it's stable so...meh, whatever works
Old April 10, 2007, 01:55 PM
Patriote's Avatar
Same thing here... And i suppose it would require a vdroop mod to get it to be accurate.
With my X6800 it needed 1.47v set in Bios to get 3.6Ghz stable. But in all windows based programs all would report about 1.44v ?!
Oh well, like you said... I just raised voltage until it was stable!
• - EVGA 680I A1
Old April 13, 2007, 04:29 AM
Misoprostol
Guest
Posts: n/a
My general rule of thumb lately has been to just keep upping it until I get a 24/7 stability. As long as my chip isn't running ridiculously hot, I don't worry about it.
~M
Pls.... help!! Looking for a more stable driver for the XFX 7600GT 256 AGP.... Canadianguy Video Cards 12 December 11, 2007 08:02 PM
4Ghz Q6600 Prime stable turtletrax CPU's and Motherboards 14 August 13, 2007 11:05 AM
