Old April 9, 2007, 11:19 AM
BALISTX's Avatar
Default Budget Athlon XP OC Build
It's time to get retro. I was digging through some of the old PC's I had and I came across something of interest that got my mind thinking "project time". I found an Athlon XP1600 (Palomino) AGKA 0149MPM and an AOpen AK77 Pro (A) VIA KT266A. I'm going to overclock this bad boy by increasing the FSB since the L1 bridge is laster cut and I don't feel like messing with it to unlock the multiplier. With that being said the multiplier is set to x10.5 with a current FSB of 133MHz (266Mhz DDR). By using PC2700 DDR333 which should give me plenty of headroom for increasing the FSB. A nice feature with this AOpen board is it allows you to increase the FSB by increments of 1MHz in the BIOS.
My budget for this build is $500 or less
So here is what I have and what I plan on getting any help will appreciated.
Have:
CPU: Athlon XP 1600+ 1.4GHz Palomino) AGKA 0149MPM
Motherboard: AOpen AK77 Pro (A) VIA KT266A ATX
Hard Drive: Western Digital Caviar SE 80GB 7200rpm 8MB IDE
Case: Generic Mid-Tower
LG 16X DVD-ROM
Monitor: Dell E&&1p 17" CRT
Keyboard/Mouse: Microsoft Desktop 5000 Wireless
OS: Windows XP Pro SP2
Getting:
Memory: 512MB Kingston HyperX PC2700 DDR33 2-2-2-5-1 2.6V (2x256MB)
Cables: Assorted rounded cables.
Need:
PSU 350W +
Video Card Support 4X AGP
CPU Heatsink/Fan Socket A
NIC: 10/100 MB/s Ethernet
Heatware
HWBOT
Old April 9, 2007, 12:55 PM
cdn_Madrach's Avatar
Kewl.. I have an xp2400 and the same board sittting on my desk. Was my first build and had a80gg hd 9800 pro My chipset fan went and I installed a zalman passive cooler on it
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
Silverstone Strider 1kw modular
4870x2
Ocz Vendetta 2
Top deck Tech Station
Samsung dvd
Old April 9, 2007, 12:58 PM
sswilson's Avatar
Heh... I had one of those boards myself..... :)
One thing I'd suggest you look at while you're OC'ing is to check out the .5 multiplier. I Know it did "bad things" to memory freqs on S939 boards, it'd be interesting to see if it affected Socket A boards as well.....
Dell Optiplex 3020 / Intel Core i3 i3-4160 / EVGA GT 1030 SC (Half Height) / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
Old April 9, 2007, 01:05 PM
BALISTX's Avatar
The multiplier on the processor I have is 10.5
Well the boards a no go, it's a dud. So I've been checking on eBay and came across an interesting find. The only prob is it doesn't support my processor but I remember rumors of an Athlon XP-M processor that's unlocked. The board is Soyo SY-KT600 Dragon Plus v2.0 for $24.00
Heatware
HWBOT
Old April 9, 2007, 01:09 PM
sswilson's Avatar
Did you try swapping out the battery? That board's been around for quite some time.......
Old April 9, 2007, 01:16 PM
BALISTX's Avatar
Yep I did and still a no go.
Heatware
HWBOT
Old April 9, 2007, 01:22 PM
sswilson's Avatar
Bummer....
Socket A boards are getting harder and harder to come by.
I know mysterybytes has some new ones listed, but I doubt any of the new ones would OC worth crap......
Old April 9, 2007, 01:59 PM
BALISTX's Avatar
Searching eBay I came across a AMD Athlon 2500 XP-M BARTON SOCKET A CPU for about $10.00 incl shipping.
Heatware
HWBOT
Old April 9, 2007, 02:15 PM
sswilson's Avatar
Sounds promising....
Old April 9, 2007, 02:43 PM
BALISTX's Avatar
Found a video card here in Ottawa for $35 Sapphire Radeon X1600 Pro 256MB AGP
Heatware
HWBOT
Budget PC Build BALISTX CPU's and Motherboards 13 March 6, 2008 08:52 AM
My new budget-ish pc kcksteve CPU's and Motherboards 21 November 27, 2007 12:24 PM
Budget system Wiked CPU's and Motherboards 15 October 13, 2007 02:49 AM
New Computer Build - $1500 Budget Kandorf CPU's and Motherboards 7 September 24, 2007 01:24 PM
Budget HTPC BALISTX HTPC Systems & Software 4 May 28, 2007 08:16 AM
