Old July 8, 2008, 08:11 AM
Level up: 8% Level up: 8% Level up: 8%
Level: 12 - 372 points to level up
Default caDAVEca's Overclocking adventures.
I popped into the Vantage thread, and kruzn4evr asked me about settings. I'm the type of guy that's never happy with one particular config, and I am constantly changing my rig, so I thought I'd chronicle it here.
FIrst, let's start with the rig specs:
Intel QX9650
ASUS Maximus Formula SE
4GB Crucial pc5300 3-3-3-12 (8FE4)
2x Radeon HD3870x2 in CrossfireX
ASUS Ageia Phys-X P1
Enemax Galaxy 1000w DXx.
The settings:
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 10
FSB Frequency : 417
FSB Strap to North Bridge : 333
PCI-E Frequency: 115
DRAM Frequency: DDR2- 1009
DRAM Command Rate : 2N
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : 3
Row Refresh Cycle Time : 60
Write Recovery Time : 8
Read to Precharge Time : 3
Read to Write Delay (S/D) : 8
Write to Read Delay (S) : 3
Write to Read Delay (D) : 5
Read to Read Delay (S) : 4
Read to Read Delay (D) : 6
Write to Write Delay (S) : 4
Write to Write Delay (D) : 6
DRAM Static Read Control: Enabled
Ai Clock Twister : Strong
Performance Level : Enabled (0)
CPU Voltage : 1.3625v
CPU PLL Voltage : 1.5v
North Bridge Voltage : 1.45v
DRAM Voltage : 2.12v
FSB Termination Voltage : 1.20v
South Bridge Voltage : 1.050v
Loadline Calibration : Enabled
CPU GTL Reference : 61
North Bridge GTL Reference : 67
DDR2 Channel A REF Voltage : DDR2 REFF
DDR2 Channel B REF Voltage : DDR2 REFF
DDR2 Controller REF Voltage : DDR2 REFF
SB 1.5V Voltage : 1.5v
NB LED Selection : FSBT Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU Volt
Voltiminder LED : Enabled
CPU Spread Spectrum : Disabled
PCIE Spread Spectrum : Disabled
I'll go through and list several different configs, what I changed, and how it affected the system. Maybe someone will find this some help!
Old July 8, 2008, 08:39 AM
Level up: 13% Level up: 13% Level up: 13%
Level: 17 - 692 points to level up
Managed to break 440FSB by any chance?
Xeon Quad X3350 | 3.40GHz (Damn X38 chipset)
ASUS Maximus Formula | BIOS RF0410
2GB Corsair Dominator | 850MHz
4-4-4-12-2T
2GB OCZ Platinum Rev2 | 850MHz 4-4-4-12-2T
HIS ICEQ4 Turbo HD4850 @ 700/1200
X-Fi XtremeMusic
Antec TruePower Quattro 850W
Antec 900
[ HEATWARE ]
Old July 8, 2008, 10:05 AM
Yes. Fully stable for 24hrs of prime, but I do not like running voltages that high for too long. The run at these settings(I keep a logbook) did however have a "burn-in" effect, and I can now run 4ghz @ 1.280v, when it used to require 1.30v.
- Ratio CMOS Setting : 9.5
FSB Frequency : 444
DRAM Frequency: DDR2- 1067
CAS# Latency : 5
RAS# Precharge : 5
Performance Level : Disabled (1)
CPU Voltage : 1.3750v
CPU PLL Voltage : 1.8v
North Bridge Voltage : 1.65v
FSB Termination Voltage : 1.50v
South Bridge Voltage : 1.100v
SB 1.5V Voltage : 1.6v
Old July 8, 2008, 10:55 AM
Yeah even though I don't have an extreme CPU, anything past 425FSB for me results in some serious voltage increases. I can use stock voltages for 425, but even for 430 I need tons more volts.
Do you find having DRAM Static Read Control: Enabled to help anything? I see most people with it disabled.
4-4-4-12-2T
X-Fi XtremeMusic
Antec 900
[ HEATWARE ]
Old July 8, 2008, 11:04 AM
If it set disabled ram bandwidth is affected negatively, more preciscely, memory writes...I don't know what that setting does, exactly, but in the end it hasn't affected my clocks at all, and I've tried adjusting it at each and every interval of stability testing that failed. I've seen many others like you have, but I also see alot of sheep copying settings, and that doesn't help me push further.
I can clockgen to over 440FSB without the high cpuPLL volts, but not boot into Vista. FSB volt increase is needed as is NB volts, for long-term stabilty, as are teh SBv increases. If i can't turn my pc off, and come back ot the same settings at next boot without playing with anything, it's not stable, IMHO. I need to use it every day!
Going much further than that, well, it can get to 470 bootable, but I get hard USB dropouts starting @ 454, so I'm running into the X38 bug before hitting cpu limits. I've gotta swap out for another board, but funds area bit short for that ATM. Not much choices out there either...and I've yet to swallow buying DDR3 again for X48, but there isn't much else left for options with this cpu.
Anyone know where to buy a Foxconn X48 BlackOPs in Canada?
Old July 8, 2008, 01:59 PM
I rarely see many Foxconn boards make it up here. Usually it's only the low-end lines.
Guess I'll enable DRAM Static Read Control then, though I doubt I'll notice a difference anyway.
By any chance have you tried using the Rampage BIOS? I see you're quoted in the thread on XS. If so, did that help your clocks?
4-4-4-12-2T
X-Fi XtremeMusic
Antec 900
[ HEATWARE ]
Old July 8, 2008, 03:00 PM
Eldonko's Avatar
Hardware Canucks Reviewer
DRAM Static Read Control has to do with the internal timings of the chipset, specifically the memory controller. Enabling = memory bandwidth so unless you are losing FSB, keep it enabled.
Re: BlackOps - haven't saw any at all.
Hockey Mod at your service
Old July 8, 2008, 05:21 PM
I found the Rampage bios posed other issues that I wasn't willing to accept. While at first it did make a difference, once successive bioses came out for the maximus, performance is within 1%, assuming you set everything manually. There is one single memory setting that would give me more bandwidth, but becuase overall latency wasn't affected, real-world difference would be even harder to notice.
XS is not what it was when I joined...still good info there, and lots of traffic, but lots of people have stopped posting the real good stuff. It's now more "I tried your settings, but it didn't work, what should I change" than even I like.
Yeah, I've noticed alot of OEMs glossing over our fine country...gonna have to drop Sham a mail.
Old July 8, 2008, 05:57 PM
The main thing I like with the Rampage BIOS is that you can set the performance level easily. Seems rather cumbersome with the Maximus BIOS. Not sure how much it really helps though...
4-4-4-12-2T
X-Fi XtremeMusic
Antec 900
[ HEATWARE ]
Old July 9, 2008, 06:09 AM
MpG's Avatar
MpG MpG is offline
Level up: 62% Level up: 62% Level up: 62%
Level: 15 - 248 points to level up
Oh hell yeah.
Looks to me like you've got a pretty good chip. I know that there are quite a few QX9650's out there (i.e. mine) that need a full 1.4Vcore to be fully stable at 4.0Ghz. I can get mine game/benchmark stable up to 4.3, but up to 1.45Vcore is needed, which is more than I'm comfortable with.
I'm presently rebuilding my main rig (with the exact same mobo/CPU combo), which I'm hoping will grab me a little extra headroom to play with. Unfortunately, the vast majority of postings out there don't bother with anything over 3.6Ghz, which is frankly child's play on these chips. So I'd be quite interested in any observations/experiences that come your way.
btw, which BIOS are you using?
QX9650 @ 4.038GHz (425x9.5) | Asus Formula Maximus | GTX280 (777/1620/1404) | Mushkin XP2-8000 Redline 2x2GB
Q6600 @ 3.6GHz (400x9) | MSI P35 Platinum | 8800GTS 640MB (700/900) | Mushkin EM2-6400 2x2GB
