Old April 9, 2007, 07:09 AM
cdn_Madrach's Avatar
Default Problem with Bios:(
Does anyone know if oc'n can corrupt a bios? If so can you just reflash it? My problem is that after I pushed my system to the point of restarting after oc'n too high some settings in bios are not working properly. My quick boot option is enabled but still runs memory scan and full boot. Also my crossfire is querky.... was working fine then now it said cant comunicate between cards. Wondering if that is dongle(not loose checked/ unhooked and rehooked up) or if the setting in the bios for which pci-e slot to boot first is not working correctly as the quick boot? I already have the latest bios and wondering if I reflash would it possibly fix one or both of these issues. Thanks in advance
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
Silverstone Strider 1kw modular
4870x2
Ocz Vendetta 2
Top deck Tech Station
Samsung dvd
Old April 9, 2007, 08:34 AM
sswilson's Avatar
Yes it is possible that either the OC mucked it up, or just the act of going in to reset it soo many times while OC'ing.
Have you tried a long c-mos reset yet? If not, as long as the system is stable you can try a bios flash. (I may end up doing one myself to see if it solves my "won't accept audigy card" issues).
Old April 9, 2007, 08:50 AM
System is perfectly stable. I did a reset that was about 2 or 3 mins long and lol took me another 1/2 hour to redo my settings as I didn't write any of them down(raid, boot order and such) In your opinion Wilson should I just reflash old file(worked good) or to the newest that only improves use with vista(which I might never install )lol.
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
4870x2
Ocz Vendetta 2
Samsung dvd
Old April 9, 2007, 09:31 AM
b1lk1's Avatar
I had that board and it was picky with the bios it liked. If I were you, I'd stick to the bios you know works. I would not flash the newest just for Vista issues.
DAILY: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 270 2GB/128GB SSD+750GB HDD+2TB HDD
Old April 9, 2007, 09:35 AM
Thanks I was thinking the same thing Cause I won't be switching to Vista any time soon.
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
4870x2
Ocz Vendetta 2
Samsung dvd
Bios related but not really a problem Il Duce Troubleshooting 2 February 1, 2008 07:56 AM
Asrock P4VM800 Bios/DMA/MemoryTiming problem Lickman CPU's and Motherboards 8 November 25, 2007 12:44 AM
Bios Flash, Please Help !! Unklmo Troubleshooting 5 October 22, 2007 04:55 PM
Bios/mem/SLI? frosty Troubleshooting 1 August 28, 2007 05:30 PM
Virtual Bios / Bios Copies Sting3r11 Off Topic 1 March 17, 2007 07:33 AM
