Old July 4, 2008, 07:31 PM
matsta31's Avatar
Default My O/C story
I am trying to O/C my E8400. I facing some issue when it is time to stabilise it. I have run out of idea about what to try so I am turning to you guys....
First my system :
Asus Maximus Se watercooled north bridge
4 X 1 gig ocz 9200 Reaper
e8400
Stressing/monitoring software :
- orthos, and I run the small FFT blend test
- Cpu-z to monitor ram timings and V-core
- Speed fan and real temp to monitor Cpu temp
- Asus Probe II for norhtbridge/Ram Temp and Volts.
- Win amp with the new weezer for my enjoyment !
My problem is the following,
can't seem to get 3.8 ghz orthos stable more than 1 hour (failed at 30 minutes and 50 minutes)
current settings are (all idle) :
V-core : 1.344 V
North bridge : 1.54 V
FSBT : 1.39
RAM : 2.03 V (these where setted automatically, i'll bump up to 2.1V, what ocz is saying, I'll report what it does)
Ram timings are what the baird is giving me automatically.
Everything is under water, so temperature of CPU is not really an issue. It goes on full load around 50-52. My norht bridge does touch the 45 degrees at these voltage. I read on the web that this could be a problem with the maximus board (unstabel around 47 ish). Maybe try re-seating it with better TIM ?
anyway I am open to suggestions.
Sold hardware again.....
Currently using WHS hardware....
Old July 4, 2008, 07:38 PM
3.0charlie's Avatar
Raise the Vcore to 1.4V. If that's stable, then you've found your culprit. Then lower it until unstable. Or raise the FSB until you reach 4.0 GHz...
Old July 5, 2008, 04:00 AM
matsta31's Avatar
Bumped the v-core 1.39 on idle, It is now 7 hours Stable
Old July 5, 2008, 04:43 AM
Mibs's Avatar
Great job, now let's see how much farther it can go!
Intel C2D E6750 @ 3.52 GHz // EVGA 680i SLI Rev. A1 (P31) // 4 GB OCZ Platinum 800 MHz 4-4-4-15 // PC P&C Silencer 750 Quad // Antec P180 // EVGA 8800 GTS 512 // Samsung Syncmaster 226bw 22" LCD
WC Loop: D-Tek Fuzion V2 // Danger Den Maze 5 // Swiftech MCP655 // Swiftech MicroRes // Thermochill PA 120.2 + 4 x Noctua NF-P12
Old July 5, 2008, 05:59 AM
3.0charlie's Avatar
There you go. Most chips require more voltage than first taught. Those 4.0GHz chips that need 1.35V are rather rare...
Old July 5, 2008, 08:07 AM
matsta31's Avatar
1 hour stable 3.914, at 1.376 V-core.
Old July 5, 2008, 09:41 AM
4.2ghz @ 1.4v for me.
:D
Old July 6, 2008, 01:06 AM
1Tanker's Avatar
Also, if you take out 2 sticks of RAM, you'll likely get a bit better O/C and or stability.
Old July 6, 2008, 06:07 AM
matsta31's Avatar
After seing the kind of voltage and limited gain in gaming went back down to 3.8 for 1.36 idle. Thanks for the help people !
