<~----> Help overclock - Hardware Canucks
Old June 26, 2008, 08:08 PM
Kappy's Avatar
Default Help overclock
Here is my system
• - Asus M3A32-MVP Deluxe/wi-fi
• - AMD Phenom X4 9850 (125W) Black Edition Quad Core
• - OCZ DDR2 PC2-8500 1066MHz Reaper HPC C/F Edition 4 gigs
• - Thermaltake Toughpower 1000 Watt
• - WD Caviar 250gig SATA II x2
• - Thermaltake Kandalf case
• - Asus EAH 3870x2
I have water cooled as well. Its just seams to me I can not hit the 3gig without getting the blue screen. Please some help out.
As of right now every thing is at 200 fps ht2 pice 100 mulit at 14x and the rest is auto.
• - Asus EAH 3870x2
• - Tochiba Regza 42" 1080p
Old June 28, 2008, 01:03 PM
Kappy's Avatar
Well I found my problem, it was my ram, I tested all 4 and they suck, so I'm off to see what OCZ is going to do.
• - Asus EAH 3870x2
Old June 28, 2008, 07:07 PM
sswilson's Avatar
Are you sure you had the ram voltage set properly?
Old June 29, 2008, 08:36 AM
Kappy's Avatar
yes the voltage where right where they should be, I remove all 4 added 1 by 1 to test the stick and , all 4 of them will not let me boot my system at all. piss off is what i am now I'm wait on OCZ see what they are going to do.
• - Asus EAH 3870x2
Old June 29, 2008, 08:43 AM
3.0charlie's Avatar
Vram maybe, what about the Vmch (the NB)? Did you try to raise it? 'cause 4 sticks is asking a lot from the Northbridge.
Old June 29, 2008, 08:50 AM
Did you loosen the timings?
Like 5-5-5-12 or 5-5-5-15 @ say 2.1v?
Some AMD boards need to run looser timings.
Old June 30, 2008, 07:02 AM
Kappy's Avatar
timing are runnning at 5-5-5-18 2.1v, also I thinking its my bois, version 1102 I be going back to version 1002. I had no problem at all, when I was on that version
• - Asus EAH 3870x2
Old June 30, 2008, 07:08 AM
3.0charlie's Avatar
Vmch?
Old June 30, 2008, 06:18 PM
Kappy's Avatar
OCZ had me do this:
First off I'd like you to try and test the memory individually. If any fail the test, at 800Mhz, then we will RMA the dead sticks. Manually set the timings to 5-5-5-18 with the command rate at 2T. Also make sure the voltage is at 2.1. If they work at 800 individually then we can do 1066. This is just to make sure they are all working. well I made to my desktop then 5 seconds later blue screen. aaaaaaaaaaa I so sad, tank god I did not sell other computer .
• - Asus EAH 3870x2
Old June 30, 2008, 06:26 PM
3.0charlie's Avatar
It's RMA time. OCZ pretty good, shouldn't be a problem.
