| Thank you, As for making the e6700 scream, my mobo is doing the screaming right now..... I have an Asus P5N-T and the Vdroop is so high that when I put the max allowed v-core (1.6) it goes down to 1.52 in occt. And at that v-core (1.52) I cant get 3.6 stable, I mean, I boot and all but I have error quite fast under torture test. Anyway I guess I could Oc my xfx 8800 gt 512 Mg..... this should give me FPS :) |
| This is entirely conjecture, but are you sure there isn't another setting that's borking your OC right now? That's some pretty serious Vcore, even most 65nm Quads (the newer steppings, anyway) can be made rock-solid at 3.6 with no more than 1.450.
__________________ QX9650 @ 4.038GHz (425x9.5) | Asus Formula Maximus | GTX280 (777/1620/1404) | Mushkin XP2-8000 Redline 2x2GB Q6600 @ 3.6GHz (400x9) | MSI P35 Platinum | 8800GTS 640MB (700/900) | Mushkin EM2-6400 2x2GB |
| Quote:
__________________ (Antec Sonata Plus 550) (NeoPower 550) (Asus P5K-E/WiFi-AP) (E4400 2GHz @ 3GHz 9x333) (AC Freezer Pro) (4GB DDR-2 667) (Asus Silent 8600GT) (AVerMedia TV Tuner) (Seagate 500GBx2 Raid 0) (LG 20X DVD Burner) (Vista Ultimate 32bit). |
| Ok I guess I need to be more precise, First, my chip is a B2 stepping, the max v-core is 1.50 according to intel. I went up to 1.60 (1.52 under load) by sheer frustration because I was not able to make anything stable and it still did not do the trick. I backed up from there, I am now 1.45, 1.40 under load and running 3.5. When I stop being lazy I wanted to see where I could back it down again. Yes I use water, and all along the temperature never went higher than 65 C under load. After reading around and around I decided that my Max intel T-case was 65 C (60 + the 5c average) Last edited by matsta31 : June 2, 2008 at 06:48 PM. |
| Yeah, the B2's seem to frequently need over 1.45 to go beyond 3.5GHz, with quite a few needing in the 1.5-1.55 range. Whether you want to run up there is ultimately up to you, I suppose. As for why you're earlier high-voltage attempts didn't get you any higher, it's possible that your chip is hitting its wall, but I still have to wonder whether there's another BIOS setting holding you back.
| Thread Tools | Search this Thread |
| Display Modes | |
