Register Sweepstakes VB Image Host Members List LAN Calendar Search Today's Posts Mark Forums Read
LinkBack Thread Tools Search this Thread Display Modes
Old May 27, 2008, 08:45 PM
Level up: 15% Level up: 15% Level up: 15%
Level: 10 - 239 points to level up
Default Rampage formula setting cpu voltage...help!!!
Hey there...
just wondering if anybody could help me !? I just traded my p5k-e wifi board for a Rampage formula, and I just can't manage to set my cpu voltage manually when I set my fsb higher than 350 Mhz...even when I set it at 1.5 volts it just won't even post. I mean, when I leave it on auto, everything's going fine, but I get temps a little too high ( like 68 degrees under load ). I find all the settings in bios a little confusing. I ain't no expert, but it's not my first oc, and I managed to have a 3.6 ghz stable for 8 hours under prime 95 with my "old" p5k-e. Any ideas of what is going on would be greatly appreciated.
Lapped Intel Qx6850 @ 3.7 Ghz @ 1.4 volts
Coolit freezone elite
Asus Rampage Formula
8 Gig Gskill pc2 8000 4x2gig
HIS HD4870X2
BenQ V2400W monitor
Pc power and cooling quad 750
Old May 27, 2008, 08:49 PM
sswilson's Avatar
Super Moderator
I'd be looking at your enhanced memory settings. Try setting the mem at a lower speed and see if that makes a difference.
Gigabyte P35-DQ6 / E8400 / 4X 1 Gig Crucial Balistix PC2 8500 / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S /
MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / Swiftech Apogee GT WB / Samsung 931BF
DFI P965-S Dark / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 /
Creative Audigy2 / NEXUS NHP-2200 / Swiftech H20-220 / Highspeed PC Tech Station / BENQ FP91G+
Old May 29, 2008, 03:01 PM
Thanks for your reply sswilson ! But I managed to fix this by clearing cmos... go figure... it worked !?
HIS HD4870X2
BenQ V2400W monitor
Forum Jump
Search this Thread:
Advanced Search
