Old March 17, 2017, 09:04 PM
yycraven's Avatar
Default Post your OC RYZEN
Just thought since no thread made yet I make one
Post your Ryzen overclock..
yycraven`s CPU Frequency score: 4095 mhz with a Ryzen 7 1700X
Old March 18, 2017, 12:40 AM
Bond007's Avatar
Thanks for sharing. If you get around to it, I am curious to see how OCing will go with a couple cores and/or smt disabled. I am wondering if that 4.1 mark is pretty much all you can expect from the silicon, or if it's just with all the cores/features running.
Old March 18, 2017, 12:49 AM
IRQ Conflict's Avatar
I have a feeling that until the memory issues are sorted everyone's score will be ~4.1Ghz.
Old March 18, 2017, 03:47 AM
A lot of us are still waiting for our mobos. Mine shipped yesterday and is going to arrive on the 22nd... 20 day wait. Sigh.
heatware
Old March 18, 2017, 05:08 AM
gingerbee's Avatar
I just picked mine up yesterday and haven't hook it up yet need to clear space from the old workstation.
And I only bought the 1700 65 TDP for the power saving and I figured the old rules may apply with early chips there all pretty damn good bins so the 1700 is a great clocked chip just turned down. i hope lmao
Old March 18, 2017, 08:12 AM
Coach's Avatar
I have not heard that before. Was that really a thing? If yes I will order one now just to have on hand.
Old March 18, 2017, 12:07 PM
yycraven's Avatar
I know there are issues with memory, as I now I am able to Oc my LPX 2400 memory to 2520MHz stable and at 4199.52 MHz running some cpu benches to see how stable it is. Temps are at 60C load.
Old March 18, 2017, 12:14 PM
gingerbee's Avatar
it's not always it just happened years ago with the old Pentium's and Celeron's but simple facts are there all the same chips with features and die's turned off. I am just betting that the first batch of 1700 were not bad bins just need a lower power chip. just my opinion
Edit wow whats your temps like at the vcore
Old March 19, 2017, 06:37 AM
warplane95's Avatar
I can't achieve 3.9GHz stable at 1.40V with the stock cooler. Waiting on my radiator to start my loop.
Old March 19, 2017, 07:10 AM
yycraven how did you get that SPi32M you put up on the 'Bot to run so slow?
Ryzen's Infinity Fabric moocow CPU's and Motherboards 7 March 16, 2017 07:45 AM
AMD Ryzen 1800/1700 available guilly CPU's and Motherboards 104 March 13, 2017 11:27 AM
Ryzen Pricing upcoast604 Rumor Mill 20 March 11, 2017 06:27 AM
Suggestion,I'd like to see in the Ryzen review. upcoast604 CPU's and Motherboards 15 March 1, 2017 06:39 AM
