Old June 23, 2016, 09:14 AM
Caldezar's Avatar
Default Overclocking X99 w/ low clock RAM?
I'm wondering how critical it is for me to buy higher frequency memory for X99 if I plan to overclock the CPU, but don't care about the memory? I am still in the purchasing phase and don't want to shoot myself in the foot by buying lower frequency RAM if it turns out that a decent CPU OC requires faster clocks on the RAM as well... But the difference in price is astronomical in some cases.
I currently have an MSI X99A Krait, and will likely be buying a 6800k CPU... And I'll be cooling with a Dark Rock Pro 3, so will likely need to buy Corsair LPX for clearance purposes.
Old June 23, 2016, 09:51 AM
Johan45's Avatar
I would aim for the 2800 -3200 range. Not sure about BroadE but for HasE that was plenty fast enough. I'm using this kit PNY Anarchy X 16GB (4 x 4GB) 288-Pin DDR4 SDRAM DDR4 2800 (PC4-22400) Desktop Memory Model MD16GK4D4280016AXB - Newegg.ca
which is onsale at newegg.ca for $130 right now. The HS aren't all that tall.
Not sure if that's my wife's cooking or if I'm overclocking too much.
Old June 23, 2016, 01:10 PM
Caldezar's Avatar
I noticed the LPX 16GB 3200 kit on sale at NCIX for $139.99, so I ordered some. Should be fast enough I would hope.
Corsair Vengeance Lpx 16GB 4X4GB DDR4-3200 1.35V XMP2.0 CL16 Memory Kit - Black - CMK16GX4M4B3200C16 - NCIX.com
Just have a CPU and GPU to buy now... everything else is purchased.
Old June 23, 2016, 01:45 PM
Johan45's Avatar
GL with the build, that ram will be fine. Good eye on the sale
What are you overclocking ,Core clock or Boost clock elmorejohn46 Video Cards 4 November 20, 2013 01:24 PM
Cpu clock spike Crino90 Troubleshooting 9 September 2, 2012 07:18 PM
GPU Memory Clock??? BFighter Overclocking, Tweaking and Benchmarking 1 May 12, 2011 06:35 PM
Clock Proggy? Dr_BenD_over O/S's, Drivers & General Software 13 January 29, 2010 11:30 PM
Pci-Clock help Dashock Troubleshooting 2 January 14, 2008 11:46 PM
