  #41 (permalink)
Old March 28, 2007, 09:43 PM
sswilson's Avatar
If it's stable, you're doing pretty good.
You've already got a 25% OC and if your temps are below 50 at these settings you've probably got some headroom if you get some better cooling.
  #42 (permalink)
Old March 29, 2007, 08:35 AM
Jim's Avatar
Jim Jim is offline
Overnight test with prime 95 no errors no warnings, idle temp 35 c ,fan now at 100% was only at half before using speedfan. So I guess try the t2 stting next right ? What I'm not clear on is why when I've lowered ram to ddr333 whys the frequency @ 208
  #43 (permalink)
Old March 29, 2007, 08:56 AM
sswilson's Avatar
Your mem is @ 208 now because it is tied to the HTT. As you raise HTT your mem freq also rises. It starts at ddr333 (166) speeds when htt is stock (200) and goes up from there. (This is why we need to use dividers on the A64s).
What was your load temp while prime95 is running?
  #44 (permalink)
Old March 29, 2007, 09:16 AM
Jim's Avatar
Jim Jim is offline
HTT thats what some mistakenly call FSB ? Load temps 45-48 fan at full speed.Thanks man now I'm clear on what the mem divider does.
  #45 (permalink)
Old March 29, 2007, 12:06 PM
sswilson's Avatar
Yep.
It's up to you now what you want to do.
If it were my system with those temps, I'd hold off until I got some better cooling, but you could try dropping the mem divider and bumping the HTT by another 5 to see what your temps are like under load @ 2550. (the HT multiplier might be OK @ 4X255, or you might have to drop it to 3).
Other than possibly loosening the memory timings, do you think you're getting the hang of how to OC an A64?
Once you've got it, it's pretty simple. :)
  #46 (permalink)
Old March 29, 2007, 12:37 PM
Jim's Avatar
Jim Jim is offline
I think so,a lot more than I did before thanks to you guys.I'll likely have more questions but will work on this info for now.You've all been a big help thanks much.
  #47 (permalink)
Old March 29, 2007, 01:35 PM
cdn_Madrach's Avatar
Nice job Jim Your doin a lot better than I did on my first OC. lol. Correct me if I'm wrong Wilson but is it true that sometimes with some boards you can get a higher oc (not always) by using a lower multiplier. Like when you've hit the wall with a certain multiplier occasionally some boards and chips will go a little farther using a lower multiplier. Hope this makes sense lol . But like Wilson Jim said watch your temps, a high overclock is useless if your burning up your chip.
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
Silverstone Strider 1kw modular
4870x2
Ocz Vendetta 2
Top deck Tech Station
Samsung dvd
  #48 (permalink)
Old March 29, 2007, 03:24 PM
sswilson's Avatar
Yep, that is often the case, but fine adjustment of memory freq also comes into play when we look at different multipliers.
I found two different "sweet spots" for my board......
One runs 275X11=3025 mem divider 180 = mem freq 252
The other runs 305X10=3050 mem divider 166 = mem freq 254
The X11 settings will post close to 3060, but if I keep the same mem divider, the HTT of 278 pushes my mem beyond what it's stable at.
Using the lower mem divider @ 10X means that the mem freq goes up by a smaller percentage of HTT increases so it stays at a level it is stable at.
(Does this make sense or should I pump out some #s from a mem freq calc?)
  #49 (permalink)
Old March 29, 2007, 03:44 PM
Lol.... no calculator needed. Thanks for the info. Just wanted to make sure I thinking the right way.
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
4870x2
Ocz Vendetta 2
Samsung dvd
  #50 (permalink)
Old April 6, 2007, 08:36 AM
Default My best OC on my FX60 so far.
Not great but apparently the Fx60's are not fond of 3ghz:(. But I will keep trying
CPU-Z Validator Database
PS: How does it look so far Wilson?
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
4870x2
Ocz Vendetta 2
Samsung dvd
OCing help please SpateD Overclocking, Tweaking and Benchmarking 4 January 23, 2008 09:38 AM
WTB: 939 OCing Mobo superdude101 Buy/Sell & Trade 1 December 28, 2007 09:57 AM
Good 939 Cooler for OCing BALISTX Water Cooling 5 August 6, 2007 07:43 PM
8800 GTS ocing problem ragenrok Video Cards 13 May 15, 2007 06:51 AM
Frustration OCing Pentium D 930 Forsaken502 Overclocking, Tweaking and Benchmarking 1 May 5, 2007 05:04 AM
