  #31 (permalink)
Old March 28, 2007, 06:32 PM
sswilson's Avatar
Holy cwap.... what's the spd on those mem sticks?
I'm thinking that loosening the cas to 3 would allow you to get a bit more freq out of that mem. (probably time do drop down another level though to keep trying to find the max of your cpu).
Looking good though, you might want to try an overnight Prime95 to see if it's stable at the current settings.
  #32 (permalink)
Old March 28, 2007, 06:35 PM
sswilson's Avatar
Oh, and you should probably start running speedfan or something similar to keep an eye on the temps.
You're probably getting close to max safe temps if you're using the stock cooler.
  #33 (permalink)
Old March 28, 2007, 07:15 PM
Jim's Avatar
Jim Jim is offline
Got bf2 running,core shows 56c.thats no big deal is it ? bios is set to shut down at 60c . yea HSF is stock. using OCZ silver paste. what should I change? whats a the correct HSF to get the temp down? heatsink is actualy cool to the touch.
thanks
  #34 (permalink)
Old March 28, 2007, 07:18 PM
Jim's Avatar
Jim Jim is offline
go to cas 3 as in setting the command thing T2 ?
  #35 (permalink)
Old March 28, 2007, 08:20 PM
sswilson's Avatar
56 is really pushing the limit if you want to get any life out of the chip. I usually draw the line at 50, and I'm a lot more comfortable with a max around 40.
As for what to use as a replacement for air?
I had great luck with a Hyper6+ on S754 semprons and my 3700+. Other folks have had a lot of luck with the typhoon.
How much room do you have in your case.... the most effective air cooled replacement HSFs are pretty big! :)
  #36 (permalink)
Old March 28, 2007, 08:24 PM
sswilson's Avatar
I'd just stick with changing the cas for now.
I found that I could clock my mem a lot higher @ (2t), but the performance between a really high mem clock @ (2t) vrs a lower mem clock @ (1t) was virtually the same.
I only mentioned it in case it was holding back your OC, but I'd advise against pushing your chip more until you get better cooling.
(Actually... if you're going to leave it as is or drop it for now, you're probably doing fine with the settings you've got).
Probably a good time for some stress testing to ensure that it's stable.
If it's stable at the settings you've got, you can try dropping the VID down a bit to see if it's stable at a lower voltage. That should bring your temps down a bit.
  #37 (permalink)
Old March 28, 2007, 08:33 PM
SHaCK's Avatar
Sweet, you got an E6 stepping, those usually clock higher than E3s!
Seems like sswilson was right on about the memory speed
What's up next ? Anything else you need to know ?
Join HCF Folding Team! Team#54196
3200+ Venice/ 330 x 8 @ 1.55v / TT Big Typhoon / IHS Off
DFI LanParty UT NF4 Ultra-D
2 x 512mb OCZ Gold DDR433 @ DDR480 1.5-2-2-5
2 x WD SE16 250gb Raid-0
Sapphire X1950XT
SilverStone Strider ST60F 600Watt
TT Armor Jr.
  #38 (permalink)
Old March 28, 2007, 09:19 PM
Jim's Avatar
Jim Jim is offline
doh!! had cpu voltage @ 1.52 dropped it to 1.42 @ current ambient ,temps are 44-46 c in game.
Running some kind of a Prime95 (not sure what it means )over night guess I should post result tomorrow ?
  #39 (permalink)
Old March 28, 2007, 09:36 PM
sswilson's Avatar
Prime95 was one of the original "distributed computing" programs like seti@home and folding@home.
It's also got a setting for a "torture test" which will drive your temps up and put as much stress as possible on your cpu.
I usually run for over 10 hrs to test for stability. (Some folks think that anything over an hour is overkill, but I have seen a failure show up after 8 hours)
|MG| Free Download - Prime95 23.8
  #40 (permalink)
Old March 28, 2007, 09:43 PM
Jim's Avatar
Jim Jim is offline
Anything else you need to know ? yep , not sure what at the moment though.
OCing help please SpateD Overclocking, Tweaking and Benchmarking 4 January 23, 2008 09:38 AM
WTB: 939 OCing Mobo superdude101 Buy/Sell & Trade 1 December 28, 2007 09:57 AM
Good 939 Cooler for OCing BALISTX Water Cooling 5 August 6, 2007 07:43 PM
8800 GTS ocing problem ragenrok Video Cards 13 May 15, 2007 06:51 AM
Frustration OCing Pentium D 930 Forsaken502 Overclocking, Tweaking and Benchmarking 1 May 5, 2007 05:04 AM
