  #21 (permalink)
Old March 28, 2007, 09:06 AM
Jim's Avatar
Jim Jim is offline
Kool man I'll get the screens ( guess I use a screen capture app as cpu-z doesn't have one right ?) . Now problem free @ 2500 by droping HT to x 4 from auto setting.What goods HT auto,thought it would adjust to keep it between 1000-1100.
  #22 (permalink)
Old March 28, 2007, 09:23 AM
SHaCK's Avatar
Press F5 :)
A screenshot will appear in the cpuz.exe directory.
HTT is a no-brainer, just keep it under 1000 so :
200fsb and under : 5x
200-250fsb :4x
250fsb + : 3x
Join HCF Folding Team! Team#54196
3200+ Venice/ 330 x 8 @ 1.55v / TT Big Typhoon / IHS Off
DFI LanParty UT NF4 Ultra-D
2 x 512mb OCZ Gold DDR433 @ DDR480 1.5-2-2-5
2 x WD SE16 250gb Raid-0
Sapphire X1950XT
SilverStone Strider ST60F 600Watt
TT Armor Jr.
  #23 (permalink)
Old March 28, 2007, 09:42 AM
Jim's Avatar
Jim Jim is offline
Nice thanks Shack , dang you guys in east Canada sure are smart.
  #24 (permalink)
Old March 28, 2007, 01:08 PM
sswilson's Avatar
Auto depends on the board you are using, and in most cases is only designed for stock speeds.
I'll bet (I'd have to look up a mem calculator, but cpu-z will give you the answer quickly..... :) ) that your mem is now getting close to DDR400 speeds @ FSB 250 on a 333 divider so you'll have to consider dropping it down to the next lower level (this is where dropping the cpu multi will come into play once we figure out the max of your cpu).
  #25 (permalink)
Old March 28, 2007, 03:28 PM
sswilson's Avatar
Heh.... just ran a quick calc and your mem is running @ 208 (DDR416). :)
  #26 (permalink)
Old March 28, 2007, 03:41 PM
Patriote's Avatar
Hey hey! I want to help too!
Going through the thread!
- Asus P8Z68-V PRO
- Intel I5 2500k @ 4.5Ghz
- Asus Geforce 580GTX DirectCUII Fermi
- 16GB Corsair Vengeance Low Profile
- Ultra X3 1000 Watt
- Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
- Corsair Vengeance 1300 Gaming Headset
- Crucial M4 SSD 128GB \ WD Caviar Black 1TB
- CoolerMaster 690II Advanced
- Dell UltraSharp 24''
- Noctua NH-D14
  #27 (permalink)
Old March 28, 2007, 05:20 PM
Jim's Avatar
Jim Jim is offline
Originally Posted by SHaCK View Post
Press F5 :)
f5 eh , can't get 1.39 to gen up screenshot.
  #28 (permalink)
Old March 28, 2007, 05:28 PM
sswilson's Avatar
I use Faststone image viewer to take screen caps and then crop/resize to what I want.
|MG| Free Download - FastStone Image Viewer 3.1Beta
Works well for me.
  #29 (permalink)
Old March 28, 2007, 06:17 PM
SHaCK's Avatar
i've just tried and it works, make sure the focus is on the CPU-Z window (single-click the window). The .bmp file will appear in the same directory as the the cpuz.exe
But anyway what sswilon said is more convenient and will save smaller screenshots, those generated by cpu-z are 700kb which is quite big to upload to a forum
Just to add in, what I do is ALT + PrintScreen, open up MS Paint and save as .jpg takes about 10sec.
Sapphire X1950XT
TT Armor Jr.
  #30 (permalink)
Old March 28, 2007, 06:26 PM
Jim's Avatar
Jim Jim is offline
oops my dumb , your right Shack , was spitin em out on the desktop , didn't notice....feels noobish
OCing help please SpateD Overclocking, Tweaking and Benchmarking 4 January 23, 2008 09:38 AM
WTB: 939 OCing Mobo superdude101 Buy/Sell & Trade 1 December 28, 2007 09:57 AM
Good 939 Cooler for OCing BALISTX Water Cooling 5 August 6, 2007 07:43 PM
8800 GTS ocing problem ragenrok Video Cards 13 May 15, 2007 06:51 AM
Frustration OCing Pentium D 930 Forsaken502 Overclocking, Tweaking and Benchmarking 1 May 5, 2007 05:04 AM
